Low oil Light
My low oil light came on. I had an oil change about 2700 miles ago which was about 3.5 months. The DIC says I have 61% oil left (usually low oil light comes on around 50%)
Should I just check the oil using the dipstick? |
Re: Low oil Light
The low oil light has nothing to do with oil life, it is telling you your oil level is low. If the dipstick shows your oil level is fine, then the oil level sensor in the oil pan is probably bad.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: Low oil Light
I would use the dipstick as soon as possible to see if the oil level is actually low.
Re: Low oil Light
Checked the dispstick and its low, what is possibly from? Is my engine suppose to be burning this amount of oil after 2700 miles and 3 months? I think the shop that changes my oil has been using 5w-30, I'm going to switch it up 10w-30 being the summer in western, ny. To burn less oil. |
Re: Low oil Light
The 5 in the 5w30 would be for the winter, so that would not do any good. But it is not a good idea to change the oil weight other then what GM recommends for your car.
Re: Low oil Light
So I should be putting 10w-30 in now?
Is 5w-30 okay in the winther? |
Re: Low oil Light
3100 or 3800?
GM recommends 10w30 for SII 3800's, and 5w30 for 3100's. I have ran 10w30 in a 3100 during the summer months with no issues. Sounds like you have a leak somewhere. Climb under and find it!
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: Low oil Light
I have 3800 series. I get my oil changed every 3k miles which equates to about 4 months. How many quarts of oil should I be burning in that timetable. Pontiac grand prix gt 3800 107k |
Re: Low oil Light
Ideally 0.
It gets 4.5 quarts which lines the oil perfectlly to the full line on the dipstick. My car leaks a little, it might be down about a half quart between changes. Its coming out the oil pan gasket and/or the rear main seal. It has not yet gotten to the point that its an issue. Are you sure it is being burnt? Do you have blue exhaust? Maybe its a bad valve guide seal. How many miles are on your GP?
Re: Low oil Light
BTW, have you replaced your valve cover gaskets yet?
Re: Low oil Light
