Old 07-22-2009, 09:00 PM
Plug42 Plug42 is offline
van ford windstar 2000 ignition lights on but do not crank
Old 07-24-2009, 11:08 AM
catvents catvents is offline
Re: van ford windstar 2000 ignition lights on but do not crank
Did you try to start it with the shifter on neutral or in moving it to every range to see if something happen? The TRS (transmission range sensor) is a regular issue on this model.
Old 07-24-2009, 12:53 PM
Off_Timing Off_Timing is offline
Just throwing out what I'm thinking. If I'm wrong - be kind. ;-)
What about a bad starter or a (partially/mostly) drained battery?
Is a no-crank condition indicative of a damaged key chip? Could that also be causing a no-crank condition?
