Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-21-2009, 10:59 AM
jbjslambert jbjslambert is offline
looking to buy 95 GST ??? help
anything i should look for, car is all stock and was owned by older lady. has 136,000 on it any help... thanks
Old 07-22-2009, 11:15 AM
torlok2002's Avatar
torlok2002 torlok2002 is offline
Re: looking to buy 95 GST ??? help
I'm no expert, but speaking from experience (http://www.automotiveforums.com/vbul...d.php?t=918743) one major thing to check is that it has had routine maintenance performed. Specifically Timing belt/water pump/etc (every 75k miles I beleive). I had my water pump fail and now I'm ont he tail end of a 6 month repair job (yeah I know it takes someone who knows what they are doing much less time...but I'm a newb to engine repair.)
Old 07-22-2009, 11:25 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
torlok2002 is 100% right. Make sure maintanence is done. That's the most important thing. Ask for exactly when the timing belt was replaced. Check for any leaks and any smoke coming from anywhere. If you have time, do a compression test, and also pull the intake pipe off the turbo and check for shaft play.
The car is not modded at all, which is a very BIG plus in buying these cars. No kids touched it, thinking they could "tune".
If you don't mind me asking, how much?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-22-2009, 08:37 PM
a guy i know has it his car lot. he bought it from the mitsubishi dealer and lady traded it on a new one .asking 4000 i think i can get maintenance info from dealer cause she always had it done there. thanks joe
btw i am knew to turbo but just grab the shaft and wiggle to check for end play?
looking to buy this as project car with my son.
would this car be a 6 or 7 bolt engine and which is better to have?
later on we want to run it at autocross, thats what i used to do before i got old, lol.
Old 07-22-2009, 10:08 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
yeah, the turbo shaft should move VERY little from side to side. in and out is ok, as long as it isnt like, loose.
the 95 will have a 7-bolt
autoX would probably be much more fun in an AWD car (GSX) but the FWD (GST) certainly can do it.
Old 07-23-2009, 12:38 PM
thanks guys. which is better the 7 or 6 bolt for mods later on? can i ask you what size your rims are and the offset. i like how they come almost flush with the car
Old 07-23-2009, 02:18 PM
Black99GST's Avatar
the 7-bolt is more prone to "crankwalk" however, take that with a grain of salt because more then 80% of 7-bolts are 'walk free... however, close to 100% of 6-bolts are 'walk free. the rods in the 6-bolt are stronger. the pistons in the 7-bolt are stronger... the head on the 6-bolt flows better out of the box. the 4g63 is a great motor either way... just take care of it. i am a firm believer in the difference between DRIVING and ABUSING the car...
rims are 17 x 8 +38mm
