Old 07-14-2009, 08:00 AM
98grandprixse 98grandprixse is offline
motor swap
I have a 98 grand prix se it had a 3.1 i found a 2000 grand prix se with a 3.8 will the 3.8 work in my 98.
Old 07-14-2009, 10:23 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: motor swap
Welcome to AF. To my knowledge, everything will bolt up just fine, but you will run into issues when it comes to the PCM and wiring.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-14-2009, 12:47 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: motor swap
as tim said...you can make it bolt up just fine...but getting it to run is a different story. you are going to want the whole wiring harness from the other car...along with the PCM, probably even want the transmission also. (dont recall if the 3.1 came with the 4T65E or the 4T60E)
edit: what is wrong with the 2000? with all the work and money that is involved in the swap...I'm wondering if you should just fix the 2000 with parts from yours
