Old 07-07-2009, 06:38 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Loose Wheel Hub?
Hey Guys,
So I had the Prix in the shop for some maint. and they told me that my driver's side (I think it was anyway) wheel hub was "loose," and needed to be replaced soon. It's probably just because I'm not the most experienced or familiar, but how does a hub get "loose?" Also, aren't those way expensive on our cars?
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 07-07-2009, 06:54 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Loose Wheel Hub?
Overtime as parts wear out, they get loose. If you done have any noise and the ABS system works fine, jack up that side and do the 9 and 3 and 12 and 6 wiggle test. If you dont feel looseness, your probably fine driving on it for now.
They arent any more expensive than on other cars. I bought a replacement for about 100.00. BCA national brand at Oreilley's. GM replacement ones are the way to go because they included new hub bolts and a new axel nut.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-07-2009, 07:20 PM
Brent S Brent S is offline
FYI, I had a somewhat loose hub from 40 k miles, and I just replaced it a few weeks ago at 130k miles. It may have even had the extra free-play very early on. I just kept monitoring it, and it really never got any worse. The reason why I replace it, was because I didn't want some idiot mechanic to fail my New York State inspection because of it. For the past 3 or 4 years, they kinda warned me, but let me slide.
Also, there's a procedure to replace it in this forum, and the 3 hub bolts can be VERY DIFFICULT to remove. It was a pain in the butt job for me. Make sure you soak them with some lube for a while, first.
Old 07-07-2009, 08:15 PM
00GTP4ME's Avatar
Interesting. I've been going to this mechanic for the past 10 years, so I'm not totally worried about them trying to screw me, but I was just curious. He did say I'd be ok for now, but that it's definitely something to keep my eye on.
If it were to get bad, would I notice any specific symptoms, or would my wheel just fall off out of nowhere on the freeway one day?
Old 07-07-2009, 08:27 PM
tblake's Avatar
In God We Trust
Yeah it would sound like a turbojet engine when you turned one direction and when you turned the other would go away (almost completly). Or else your ABS and trac off lights will light.
Old 07-07-2009, 08:31 PM
00GTP4ME's Avatar
Ha, ha, ha, well that's good to know. I had a friend who had a little Lancer a few years back and we were driving along and I looked at her and asked why it sounded like we were inside of a locomotive. She said it had been driving her crazy and she didn't know what it was. Trying to sound smarter than I am/was, I told her I bet that her wheel bearings were out. A day later after she got it back from the shop, she said I was right and always came to me for automotive advice after that. (not her, me)
On our cars, the hub and bearings are all one piece right?
Old 07-07-2009, 10:12 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
correct.
Old 07-08-2009, 07:51 AM
To elaborate: My hub/bearing just had some extra free-play, when you do the 12 & 6 O'clock shake test. It wasn't a lot, but the other wheel had no free-play. And when the old hub was off the car, it was even harder to feel the free-play, probably because you don't have the lever-arm advantage of gripping the outer diameter of the wheel/tire. I just didn't want to take the chance with this ridiculous New York State inspection; some things I really hate about this state.
Old 08-10-2009, 07:38 PM
00GTP4ME's Avatar
So it's been a little while now and the driver's side hub has about a 1/4" of play in it. Time for a replace? Could this contribute to wheel studs breaking? I've never had a wheel stud break until I got this car.
Old 08-11-2009, 07:51 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Do you have any wheel shimmy while driving? Most people or mechanics do not test for wheel bearing slop properly. How many miles do you have?
It takes BFFI to break or snap off the wheels studs. If you use the proper tools like a torque wrench then you should have no problems. 100 lb-ft is all it takes for proper torque.
I recently replaced the drivers side hub in my GTP because my son broke two of the wheel studs off. He works out too much and bench presses well over 300 lbs. Classic example of a BFFI.
Timeslip 08/12/06
AF Community Guidelines
Old 08-11-2009, 08:01 AM
When I gripped my wheel at 12 & 6 O'clock and shook it, I was able to get approx 1/4" play. I drove on that bearing for a few years, and it never got any worse. But, I checked it every time I did an oil change. If there's no grinding noise/feeling, you may be able to wait a little while (especially if it's not getting worse), but eventually you should just "bite the bullet" and change it out. That's my opinion.
Old 08-11-2009, 10:28 AM
00GTP4ME's Avatar
Hey Bob! I do feel a little more vibration that usual when I'm on the freeway. The shop said that with the bearing how it is, it makes it difficult to do a perfect alignment. They also said that as it is now, it technically wouldn't pass safety inspection, although I don't think they'd fail me (moot point as I got it done (and passed) a month ago). What is the proper way to check "slop?" Right now I've got 129K miles on the ol' girl.
Old 08-11-2009, 08:10 PM
BNaylor's Avatar
With over 100K miles it is not uncommon for the wheel bearings to get free play so what the mechanic is telling you is probably true. The proper test is to safely jack it up, remove the wheel, put wheel nuts over the rotor to keep it secure on the hub, pull on the rotor at 12 and 6 and 9 and 3 positions but using a dial gauge and comparing the runout/slop to the service manual specs.
Now as to mechanics being truthful or knowing what they are saying or doing. Back to my GTP. I took it to a local Firestone shop for a 4 point wheel alignment. It all came out within specs. But on the inspection sheet the mechanic stated the left wheel brearing/hub felt sloppy. I almost broke out in laughter. That was the hub I just replaced and used the proper torque figures for the axle nut on top of that. I asked the mechanic if he noticed the hub was brand new (AC Delco) and he stated no. He didn't know what to say. Oh well so much for that.
Timeslip 08/12/06
Old 08-11-2009, 09:23 PM
tblake's Avatar
In God We Trust
Bob, maybe the dummy didn't realize the left side is the driver side.
Old 08-12-2009, 07:31 AM
BNaylor's Avatar
Same guy that did the wheel alignment. Does that means my alignment specs are all backwards?
He knew. He was just trying to make some extra money for the shop. Plus the right hub was replaced a few years ago and only has about 800 miles on it.
Timeslip 08/12/06
