Old 04-02-2003, 12:59 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Crank Pulley
Hey... how do I get the crank pulley off of my D16Y8? Do I need some kind of special tool to keep the crank from turning?
Old 04-02-2003, 01:16 PM
turbcivic's Avatar
turbcivic turbcivic is offline
An impact gun or if is tighter then that, we use a bar that holds the nut on the pully up against the bottom of the car and break the bolt loose with a breaker bar.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 04-02-2003, 03:33 PM
ci5ic's Avatar
Well, I don't really think it's all that tight, I just can't loosen it because when I wrench on it, the crank turns. And the engine is not in a car... I noticed that there is a really large hex-shaped indent on the pulley, and I'm wondering if there is some sort of tool that fits inside it in order to hold the crank in place while wrenching on the bolt... ?
Old 04-02-2003, 03:40 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
can u use an impact ? cause if u can, the crank wont turn. if not then jam a screwdriver into the flywheel, theres a little plate that covers it, just gotta take that off.
Team Lonely Drivers
Old 04-02-2003, 04:39 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
or if you can't do that and have access to a welder or someone to weld you can get creative and build a barcket to go in the hole and up onto the body, but it has to be friggen strong... my dad did that once heh, but i'l always just used the impact gun on mine
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-02-2003, 05:04 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
there is a special wrench that honda makes. i have one here at the acura dealership that we use on integras all the time. its a big hex head with a hole down the middle to put a socket through, you just put the tool on, and brace it against the frame or the ground, and then go at the bolt with a breaker bar
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-02-2003, 06:24 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
impact gun worked for me.......ahh the power of air
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-02-2003, 07:55 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
DONT put a screwdriver in the flywheel, i broke off a huge piece of the bell housing of my tranny becasue i tried doing that one time..
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 04-02-2003, 08:37 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
That thing was our best friend when we were working on the accord the other day .. also this prybar type thing he had was awesome
http://www.automotiveforums.com/vbul...ghlight=accord
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 04-02-2003, 08:48 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
If you carefully wedge a long pry bar thru the flex plate it will work, i had to do it the other day.....otherwise honda makes a tool for it...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 04-03-2003, 02:45 PM
turbcivic's Avatar
Ya that was what i was talking about. At honda, we have a shop gun that gets the crank pulley bolts off no problme, 1000 lb torque in reverse
Old 04-04-2003, 02:40 PM
darolh darolh is offline
Impact gun......and it may need to be a good one. The first two I tried wouldn't do it so I went out and bought a good one. Ingersoll-Rand.
Old 04-04-2003, 04:54 PM
for my impact, i have a craftsman, the stock 90psi didnt work, so i just completely filled it with oil, turned it up to 150psi on the compressor, and bam it spun right off
Team Lonely Drivers
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
WTB: Mass Area Crank Pulley & Power Steering Adjuster Pulley invictus_92 Probe 0 12-23-2004 10:24 AM
crank pulley removal RickDaTuner Engineering/ Technical 6 03-26-2002 08:22 AM
Crank Pulley Prep soul180 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-11-2002 11:26 AM
Lightened Crank Pulley from UDP Austin Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 07-12-2001 04:57 PM
