Old 07-03-2009, 08:09 PM
goodoldpapa's Avatar
goodoldpapa goodoldpapa is offline
Windshield Washer Reservoir Replacement
I need to eventually replace mine as it has a crack in it somewhere and will leak out if I fill it more than 1/2 way. I was just wondering what all is involved with it as I would like to do it myself if at all possible. Thanks.
Old 07-04-2009, 10:27 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Windshield Washer Reservoir Replacement
- First remove the drivers wheel.
- Then remove the plastic inner fenderwell, several 8 or 10mm bolts and a few push pins.
- Might also need to remove the lower splash shield which runs up to the front.
- Unplug the wire harness to the washer pump, a couple bolts hold it on the fender/uniboby.
You can also check out the CAI R&R in the Tips & Maintenance sub forum for some pics of this area.
Hope that helps
1999 Grand Am SS 3.4 OHV
