Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-21-2007, 09:22 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Post Installing a Cold Air Intake - For V6 Models 96+
Installing a Cold air intake (CAI)
This is about a 30-40 minute job.
Of coarse you will need a CAI.
- First remove the stock air box lid , and remove the air filter.
- Loosen the clamps on the Throttle body and MAF sensor.
- Remove the rubber boot and pop out the PCV vent and IAT sensor on the right of the air intake tube.
- Remove the 3 10mm nuts holding the lower air box in place and remove that.
- With that removed it should look something like this.
- Next jack up the front drivers side of the car and remove the wheel for ease of install.0
- Now you need ro remove the push pins holding the inner fender splash shield on. A panel tool works best for this so you dont damage them. Red circle is a 10mm nut that holds the factory duct inside the fender.
-A better pic here .
- Now you'll need that 10mm socket to remove the bottom panel screws
(or push pins) to fully open up and remove the old air intake tubing/pieces.
- Install the tubing between the MAF and throttle body.
- Dont tighten the clamps all the way untill everything is put together and lined up.
-Now insert your long tube down through the bottom of the hole where the old duct came through.
- Connect the other end to the MAF.
- Now put the filter on the end of the long tube inside the fender .
- Now install the PCV vent pipe, the IAT sensor and plug the MAF back in.
- Making sure the wires are able to reach the corresponding connections.
- if not readjust the intake tube so they will reach.
- Tighten all the clamps on all of the cuplers now.
- Should look something like this.
- Reinstall the bottom panel, and fender splash shield.
- Install the wheel, torq to 100ft lbs.
- Lower vehicle.
Start the car to make sure things are in working order.
Now enjoy your CAI
1999 Grand Am SS 3.4 OHV
Closed Thread
