Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-03-2009, 03:59 PM
jd901 jd901 is offline
96 marguis only heat blows from a\c
my 96 marguis only blows heat.its full of freone ,no leaks and compressor still works..whats the problem??
Old 07-05-2009, 05:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 96 marguis
Check the blend door motor. Sounds like that might be your problem. Get in car, close door, turn key "on", wait for any warnings to stop, listen for a small motor noise while moving the heat control lever from cold to hot.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 12-22-2009, 08:05 PM
Scary1 Scary1 is offline
Re: 96 marguis
My 96gm does the same thing intermittenly. I found when the weathers cool the blend door motor hums open/close, but won't work when the weathers warmer.Did you have any luck with yours I was thinking it might have something to do with in cabin temp sensor.
