Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-24-2009, 07:25 PM
2005chevimpala's Avatar
2005chevimpala 2005chevimpala is offline
too much tranny fluid
can anyone tell me a fast way to take out a quart of tranny fluid,made the mistake of putting a quart in the tranny checking the fluid when the car was cold,i find the tranny like it's binding up or something like she won't free roll when driving feels like my foot is on the brake a little,need to drain some out,next time i'll check when hot,whats the best line to let go to drain the fluid out
Old 06-24-2009, 10:33 PM
troy1 troy1 is offline
AF -Advisor
Re: too much tranny fluid
One qt over will not cause the problem you are describing.
Old 06-24-2009, 10:54 PM
j cAT j cAT is offline
usually 1 qt over will cause foaming of the fluid and bad shifting...always top off when hot...slowly a few oz at a time...
to remove with out wrenches use a hand pump with a 3.5 ft of 3/8 plastic tubing....I have a gear oil hand/qt bottle pump that with the 3/8 tubing will quickly suck out the fluid...stick tubing down the fill/dip stick tube...
Old 06-25-2009, 04:16 AM
yes the tranny fluid is very foamy,the problem that i was telling you about where it felt like i was driving with my foot on the brake and she was holding back was the 2 front brake calipers,had a friend of mine do the fr rotors and pads as i never had the time and he told me he tightened the caliper bolts with a johnson bar and the bolts were on nice and tight so i took the bolts back out and retightened with just a regular 15 mm wrench and now the car is fine,think they were on so tight the calipers could move at all causeing her to stick
Old 06-25-2009, 09:25 AM
do not drive that vehicle until you remove the excess fluid...air in the fluid will damage the transmission ....
after you suck out the fluid let the fluid settle down air bubbles collapse then start ///idle fwd rev for a few times...no driving and slowly add to the lowest level on the stick..and when you see no bubbles...
go for a ride at slow speeds then after 20min of driving on level ground slowly add a few oz. until it is at the bottom of the normal operating range....
every day for a week check the level when hot on level ground ,,at the same parking area ,,,see if you need to add more..it may take a week to get out the air trapped.....
Old 06-25-2009, 05:28 PM
wafrederick wafrederick is offline
Banned
Also check it in netrual instead of in park.One transmission shop in my area does this on all transmissions and finds it is more accurate
Old 06-26-2009, 09:41 AM
ok thanks guys,bought the tube and pump for $3 at walmart drianed it out,no more bubbles,thanks
Old 06-28-2009, 09:47 PM
Iflylow's Avatar
Iflylow Iflylow is offline
The owners manual has a procedure for checking/adding tranny fluid.
