2002 3.1 grrand prix hesitatation
my pontiac has 105,000 miles recently started bogging down upon acceleration rpms go up to 5 grand then it shifts.on highway its not as bad but still get theat little hesitation.any suggestions would be appreciated.
2002 grand prix 3.1 sluggish during accelaration
my vehicle has 105,000 miles recntly started to bog down during acceleration especially going up hills .when the pedal is pushed to accelerate the rpms go up to almost 5grand and then shifts .on highway its not as severe but you can feel it .any help would be appreciated
Re: 2002 grand prix 3.1 sluggish during accelaration
Merge the two threads possibly? As I think both issues are related if not one in the same.
When was the last full tune up done on your car? I know 2002 GP's have known issues with cat converters clogging up, GM is aware of the issue and extended the warrenty to 120,000 miles. However I think that the extended warrenty only applies to the 3800 2001 and 2002 GP's. You could to a vacuum test on your motor to confirm/rule out the cat converter as your issue.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Re: 2002 3.1 grrand prix hesitatation
Is your SES light on?
those are the same threads, i;m sure the car could use some new plugs and wires not to fond about working on these cars any tips would be appreciated and as far as checking the vacuum how do i go about doing that thanks
Yeah, I'd check vacuum as the first step to verify the converter isnt plugged.
you can rent a vacuum guage from advance or oreilley's. Hook it to an unported vacuum line. I know the late 3100's if they dont have an air pump, have a vacuum cap on the drives side towards the radiator of the intake plenum. You can hook in there. your car should show about 16 inches of vacuum at idle, then increase the rpms to 2000. As you increase, the vacuum will drop, and then jump back up and should remain steady as you hold it at 2000. If vacuum dropps, chances are the cat converter is plugged.
threads merged
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
thanks for the help will give it a shot this weekend will keep you informed on what i find.
thanks to tblake put new plugs,wires and also the catalytic converter car runs like a champ now thanks again for your help
