Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-18-2009, 06:47 AM
Dutchinohio Dutchinohio is offline
Valve work- 99 P71
Results of a recent compression test are below:
Results are dry/wet...
1) 130
2) 110/130
3)130
4)110/125
5)110/125
6)130
7)110/125
8) 0/0
I am hoping for a broken valve spring or jimmied cam follower that I can easily repair.
Once the valve cover is off, how far down do you have to disassemble the head to replace vlave springs or cam followers? Any special tools needed? I have the tool to use compressed air to hold vlaves in place with springs off on an assembled motor and the valve spring compressor to use with it on a standard pushrod motor. Will these be of any use to me on this project?
Thanks!
Old 06-18-2009, 06:44 PM
rhandwor rhandwor is offline
Re: Valve work- 99 P71
Make sure the valves are closed and the air is in the cylinders before pulling a spring.
Old 06-18-2009, 06:59 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Or stuff a small rope in the cylinder and rotate the engine by hand until it lockes the rope to the valves.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
