Old 04-01-2003, 03:26 PM
Vric's Avatar
Vric Vric is offline
Need help stripping paint
Hi
I got a problem with my enzo..
I painted TS30 Silver leaf paint and added Testor Clear coat (the good one) as far, it's not a problem... but when dry, there is 2 small hair on the hood. so I need to sand and repaint (Tamiya Paint over Testor clear coat.. don't even think doing that !!)
Is there a trick to remove the paint in the corner and hard small place ? I can remove 95% of the paint, but I really need to get rid of everything..
If I can stay away from stuff like Superclean or thing that hurt the plastic, I would apreciate
Old 04-01-2003, 04:01 PM
ae86_takumi ae86_takumi is offline
I would try an old toothbrush.. just try harder. But I know it's difficult to remove paint out of seams and corners.
Current Project/Last Completed
Old 04-01-2003, 05:02 PM
Vric's Avatar
the hardest part is removing the clear coat ! Pain't isn't very hard to get off and even if some paint is left, it won't react.. I only need to stip all the clear coat
Old 04-01-2003, 05:09 PM
daggerlee's Avatar
Get some Mineral spirits, a toothbrush, and prepare to scrub really really hard..
Dan
Old 04-01-2003, 07:42 PM
efi-street efi-street is offline
Re: Need help stripping paint
Originally posted by Vric
Hi
I've never had any problems with CSC damaging the plastic even when leaving a body in it overnight.
Clay Marlow
www.efi-street.com
www.cottonsperformance.com
'03 Cobra - Ebony - 404 RWHP - Stock + CAI
'87 GN 31k miles
Old 04-01-2003, 09:07 PM
Re037 Re037 is offline
Send a message via AIM to Re037
ditto, i left in bodies for 1 week and the plastic is still good. might differ for different plastics, but CSC does the trick
moo moo
Old 04-02-2003, 03:02 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
Yeah. I'd use Castrol Super Clean Degreaser. It will remove the enamel clear coat, but not the Tamiya paint. I've never even had CSC mess with tamiya's paints. I'd leave it submerged in CSC for 1-2 hours and then use a toothbrush to get the stuff out of those small corners. Never use that toothbrush to brush your teeth again, and make sure you use some chemical resistant gloves whenever you mess with the stuff. You can also use brake fluid in the same fashion. Slightly more expensive, and it will take to back down to bare plastic again (although I've heard of it making the plastic brittle). HTH
Old 04-02-2003, 03:09 PM
Vric's Avatar
I finnally tryed Wet Sand paper 450grid.. worked good.. now I need to wait an other week and wait for the clear coat..
thanks
Need help...Strip paint off plastic... SuperDan180 Car Modeling 14 02-11-2009 01:08 PM
Newbie here! Need help with Painting! skh_austin Car Modeling 2 09-30-2002 12:51 AM
Need Help with painting my 300ZX jon364 Car Modeling 1 06-24-2002 05:42 PM
Need help with paint removal from farbic on a chair.. Wishmaster Car Modeling 9 05-11-2002 08:45 PM
need help re: painting on window qtip Car Modeling 7 03-31-2002 05:15 PM
