Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 06-15-2009, 12:48 AM
domesticdisturbans domesticdisturbans is offline
just got my jeep
rocking a 2003 jeep tj strong runnignthing bought it with 20k on it perty cheap only the bad thing is i need soem tires for it it has no lift and i will daily drive it so no need for one ... yet but im looking into some lil bit larger tires maybe 31x10.5 but in goodyear they do the 275 blah blah balh how do i convert it to 31 to the 260 somethign or 245 what not?
maybe just under 31's if its liek sockets metric vs standard and all but something just bit bigger then these stock 30x9.5 anyhelp woudl be appreciated and sorry if this had been coverd before i ruffled through quickly didnt see that compared to the "will this fit" as much
Thank you for your time
~Shawn
Old 06-16-2009, 11:34 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: just got my jeep
Here's a good site that has a tire size calculator:
http://www.1010tires.com/TireSizeCalculator.asp
Or you could do it the old fashioned way. 235/75R15 means that the tire is for a 15" rim, and the height of the sidewall is 75% of the 235mm treadwidth, or 176.25mm. Multiply by 2 for both sidewalls makes 352.5mm. Convert mm to cm to inches: 352.5mm = 35.25cm / 2.54 = 13.87 inches, added to your 15" wheel makes 28.87 inches high for this tire.
See also this thread here at AF for discussion on what tires will fit without modification.
You can compare many brands of tires at www.tirerack.com
Welcome to Jeep!!
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
