Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-29-2005, 08:06 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Tire size and clearance 97 - 06
There have been numerous threads about what tire sizes can be mounted with no lift, 2" lift, and 4" lift, etc. Maybe it would be helpful to have one thread to document what people have.
New Wranglers can be purchased from the factory with either 30x9.5R15, or the Goodyear MT/R 245/75R16. Doing the math, the MT/R comes out to 30.46x9.64. This is without suspension modification.
If you have a larger tire and/or lift, post here so others can have a reference.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-31-2005, 08:54 AM
Saxonwolf's Avatar
Saxonwolf Saxonwolf is offline
I'm running 33x12.50R15LT ProComps with a 4" lift on my TJ, and I have about 7" of clearance between the top of the tire and the bottom of the fender flare. Plenty of clearance for me.
Old 03-31-2005, 05:38 PM
JeeperRich JeeperRich is offline
Re: Tire size and clearance
I've got 31" x 10.5" on a stock TJ(Sahara). I get some tire rub with steering close to lock, and the tires get close to the fenders when flexed. No rubs on the rear tires at max compression.
Old 04-01-2005, 11:21 AM
darnjeep darnjeep is offline
Send a message via Yahoo to darnjeep
I am running the same as JeeperRich, 31x10.50's on a Sahara with no lift, just a little rubbing when turning sharp, so I just don't do it and it's fine.
Old 04-01-2005, 02:48 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I'm running 33x12.5 on my 1995. I have a 2.5 in suspension lift with 1 inch shackles. I'm running 15x8 wheels with a depper offset to avoid rubbing. I have almost 5 inches from top of my fender to tire and I took off my rear flares. No rubbing anywhere no matter where I drive.
Old 05-19-2005, 10:51 AM
fmrmti fmrmti is offline
I run 31" x 10½" on a stock 97 Sahara. The fronts did rub during tight turns, so I shimmed the turn stops with two washers and now they don't rub at all...still very good turning radius. No rub on the fenders, front or back. This is a great setup, especially with the 4.0L!
Old 05-26-2005, 01:25 PM
o|||||||o o|||||||o is offline
Send a message via AIM to o|||||||o
I am running 33x12.5x15 TrXus M/Ts on AR 767 wheels with 3.75" backspacing on a 2004 Jeep TJ with a 2" budget boost and a 1" body lift without any issues at all. Even under full-flex with the front swaybar disconnected I can stuff the tires and not rub whatsoever.
2004 Jeep Wrangler Rubicon (Modified a lil' bit)
2003 Honda VFR 800 (All stock w/ABS, just like Honda built it)
2001 Ford Crown Victoria Police Interceptor (It looks like a cop car because it is one)
Old 06-01-2005, 09:34 PM
MadCactus MadCactus is offline
When I bought my 98 Sahara, it came with 33x12.5x15's without a lift (it was used), don't shoot me, I didn't know any better at the time. Let's just say I had no turning radius, and curbs gave me troubles. They're most likely the reason why my stab arms went out. On the plus side though, I got free miles since my spedo wan't recalibrated either.
Well, I got rid of those tires and now have 30x9.5x15's, and I have no troubles.
Old 06-11-2005, 09:27 PM
jeep32225 jeep32225 is offline
I was running 31x10.5x15 on a 2002 TJ with no rub at all. Clearance during flex was a problem. In stalled 2 inch left no problem.
Old 06-14-2005, 02:33 PM
Just found this reference......
http://www.800-923-jeep.com/techCorner/tires.cfm
Old 07-01-2005, 10:53 PM
macdad626 macdad626 is offline
I am running a 31 10.50 on my wrangler with a 2 in coil spacer lift and I have no problems, clearance is good under flex
Old 07-02-2005, 09:46 AM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
At the beggining of the year JP did an article in which they stuck 35" 12.50"s under a factory no lift TJ. It was a 2 piece article, very interesting.
Old 07-03-2005, 08:04 PM
roy95jeep's Avatar
roy95jeep roy95jeep is offline
95 YJ 3.5 BDS lift ,m.o.r.e. 1/4 in boomerang shackle on rear and BFG 33x12.50 AT .
No problem with this setup....33s are the biggest I'll go right now, due to the dana 30 & 35
Old 10-26-2005, 09:15 PM
jeepformetoo jeepformetoo is offline
im running 31 x 10.5's on my stock 1990 wrangler yj no rubs at all
Old 11-13-2005, 07:10 PM
ufatbasted ufatbasted is offline
I running BFG AT KOs 31x10.5 with a 2.5 Rubicon express lift and 1" body lift. Still have stock rims so I had some rubbing at full turn, added a couple of washer to my steering stops to fix that til I get new rims
