Old 06-12-2009, 10:08 PM
chrisanthony chrisanthony is offline
Under hood engine cover
Hi
I find that my engine gets really hot and wondering if it would help by taking off the cloth padding that's hooked up under the hood. Would it help to dissipate the heat?
Thanks
Please checkout http://www.automotiveforums.com/vbul...d.php?t=946436
Old 06-13-2009, 01:15 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: Under hood engine cover
Nope.
Better to solve the cause of the overheating.
Old 06-13-2009, 11:26 PM
CrapaTaurusWrecks CrapaTaurusWrecks is offline
That cloth is there to protect your hood from the engine heat. If you remove it it will lead to oxidized/faded paint and eventually rust.
Finding the reason your car is overheating is the best option. The thermostat, radiator, and cooling fan are all easy to remove and replace and a good place to start your search.
Good luck
Old 06-15-2009, 08:22 AM
Good luck
Thanks for the explanation, i well not remove the cloth. It seems that everything is in working order. When i get home after work, i check the engine and its like a oven in there, i can't even touch the engine its that hot, maybe this is normal. The drive is usually 40-45 mins.
