Old 04-01-2003, 10:42 AM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Alternator doesnt work right in rain, WHYYYY!!! PLZ Help
Alright I've been having electrical problems with my car for about two weeks now, and noone has been able to help me, so now i need you guys to give me you expert advice. Heres the symptoms:
-When driving in the rain or when doing hard stop and go traffic my vents become louder and if i have lights on they become brighter while accelrating, but when its just idling they go back to normal and sometimes become dimmer than normal. Also my battery will flicker on and off while accelerating too. Usually after driving for about 5-10 min at a constant speed, everything goes back to normal again.
-Also, occasionally when driving in dry conditions, if i go long distances (like 30 or 40 miles) or just drive it hard i get a burning smell coming from wat seems to be my alternator or the belt.
Now i wat most of you are thinking, its either the alternator or the alt belt, but i replace the alt about 2 weeks ago and the belt about 1 week ago, and the alt has been tested twice and both times was charing fine. Has anyone ever had this prob or does anyone have any ideas? Cuz everyone i've taken it too is stumped, which doesnt help me out lol. Any and all help is greatly appreciated, thanx in advance.
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 04-01-2003, 10:45 AM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
Check the tension on the belt and check the pulley for wear.
Old 04-01-2003, 10:48 AM
The belt tension is fine, cuz ive tightened it like 3 times now lol. But i havent looked at the pulley, are you talkin bout the one on the engine or the alt itself? Either way, wat do i look for to see if the pulley is messed up?
-BMan original
Old 04-01-2003, 04:49 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
ever check to see if your battery is still good ?
Team Lonely Drivers
Old 04-01-2003, 07:29 PM
The battery is only a month old, and my connectors are clean too.....any more ideas?
-BMan original
Old 04-01-2003, 10:14 PM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
how do the battery wires look ?
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 04-14-2003, 01:52 AM
b16a3sol b16a3sol is offline
does that belt run along the a/c compressor as well? if so i would look at that and see if its about to seize, causing any other pulleys that are affecting by the same belt to stop turning.
the other question is, are you having any mechanical problems with the car as well that could be noticed down the line with electrical problems? if you are having problems with one part, that is working fine, go back a step and see what affects that part to try and find the problem. see if there is anything else going on when you are having electrical problems.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 04-14-2003, 01:22 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
Re: Alternator doesnt work right in rain, WHYYYY!!! PLZ Help
You may want to check your wiring harness that runs right underneath your intake manifold, the harness's have been known to rub against the intake manifold brackets causing them to fray and start shorting out on the metal. When you accelerate or brake hard or in the rain you are most likly to have this problem. It can be a bitch to locate exactly were the fray is but I bet that is your problem, good luck!!
Old 04-16-2003, 08:31 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
may be a diode in the voltage regulator. it may do it on hard stops etc because of load and the problem may get worse when it rains because of moisture fouling with it even more. or if you car has an electrical load detector look into that.
60%+ of alternator problems are either load or voltage regulator related
Old 04-26-2003, 12:26 AM
knorsk knorsk is offline
#1 If you have a yo yo daddy all bass sound system...you'll need a capacitor to regulate the voltage so you don't mess up your alt. or batt.
#2 depending on how you use your car...do you sit and listen to the radio with the engine off a lot? Do you honk your horn and blast your system with the engine off...etc
#3 If you replace your alt. there are a few things (I forget) but just read the directions because if you mess with it a certain way it becomes faulty from charge or something.
#4 Don't tighten your belt too much...you need a moderate amount of give...roughly 4-10mm
#5 It might not be the alt. giving you the problem. It could possibly be your A/C pulley if you have A/C...Try having someone look at the pulleys with the A/C off and then turn it on full blast and see if anything looks funked up in the engine.
#6 If you have poor after market pulleys they might be funked from the tension/stress that your engine puts on the pulleys. If they are super light and are not solid they are week..and tightening the belts might damage the pulleys
#7 it could be your fuel pump is going and not keeping the car at the correct idle...keep it full to sustain the full pumps life esp. if you live in a cold climate
#8 timing of your distributor could be fucked up or missing...not bad enough to knock or detonate but just enough to jerk the RPM's and not give enough power to the accesories
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
1998 CVPI serious issue right now, need real help b4 i get raked for more $$$ Towboss1971 Crown Victoria 1 06-20-2010 12:39 PM
1999 honda accord pass door not working right.plz help Nate.D How-To's and Walk-Through's 2 08-14-2009 08:42 PM
Air-Vent selector not working right. (Vacumm Issue?) Help! jgeib Dakota 2 11-07-2005 11:51 AM
speedo works when it wants???????? plz help!!! ShoofIsLudin Engineering/ Technical 6 01-10-2004 02:13 PM
Will +42 offset work on my CRX? Plz help asap branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 7 02-04-2003 12:34 AM
