Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-12-2005, 10:31 AM
jgeib jgeib is offline
Air-Vent selector not working right. (Vacumm Issue?) Help!
I always have air coming from my front (panel) vents. If I switch it to floor, the air re-directs to floor momentarily and then goes back to panel vents. On defrost, it comes out of the defrost and panel. It didn't used to do this, why now? Summer time I use the panel vents for A/C, but winter is coming and I don't want hot air blowing in my face. I've got an 01' Dakota, 4.7 SLT, Club Cab, 4x4 if it helps or makes a difference. Somebody have any ideas of things to check out? I'm guessing it is a leaky vacumm line, where should I look?
Old 11-05-2005, 07:05 PM
tyler005 tyler005 is offline
Did you reslove your problem? I'm having the same problem. Thanks
Old 11-07-2005, 11:51 AM
fasstdak's Avatar
fasstdak fasstdak is offline
Send a message via Yahoo to fasstdak
Depending on model options, most are electronically controlled now (no more vacuum lines). It could be a bad AC Head Unit, Broken Mode Door actuator (or hinge), or just a faulty actuator. Best thing to do is check for ATC codes (DRB-III) - if applicable (model options come into play there), or just look under the dash and watch the actuators while someone is changing the settings on the dash.
Chrysler/Dodge Certified Technician
1997 Dodge Dakota SLT - V6/5spd CC
Carillo Rods, KeithBlack Pistons (10.75:1), Ported & CC'd Heads, Crane Rockers (1.7:1), CompCams custom camshaft, Mopar Drive Gear, Smith Brothers Pushrods (7.050"), Ported Factory Intake, APS 50mm TB, APEXi SAFC-II Controller, JBA Headers, Magnaflow "TurboXL" Muffler, Cloyes True-Roller/Dbl-Row Chain with tensioner, etc. Dyno Proven: 214RWHP/238RWTQ (Without the Nitrous)
http://www.dodgetrucks.org/fasstdak
