Old 06-09-2009, 12:22 AM
Van2000GTP Van2000GTP is offline
2000 GTP alignment specs
Does anyone have the front and rear alignment specs (camber, caster, toe, etc...) that you can post for a 2000 GTP? Are these the same or different than for either the SE or GT models?
Also, which of the specs are adjustable on the 2000 GTP? (I was told that there is no adjustment for my car for caster.)
Thanks in advance!
Old 06-10-2009, 01:18 AM
bc_monzai's Avatar
bc_monzai bc_monzai is offline
Re: 2000 GTP alignment specs
The alignment specs are the same regardless of model.
Code:
Document ID# 580733: Wheel Alignment Specifications
Operation            Service Allowable     Service Preferred
Front Suspension
  Camber (Cross)       -1.40 to -0.40           -0.90
  Caster (Cross)        2.50 to 3.50             3.00
  Steering Angle       -3.50 to 3.50               0
  Toe (Total)           0.30 to -0.10            0.10
Rear Suspension
  Thrust Angle         -0.15 to 0.15               0
  Toe (Total)          -0.40 to 0.20               0
The GM manual describes adjustment procedures for front/rear toe and camber. There is no procedure for caster since it is not adjustable on these GP cars....unless you bent something and need the frame straightened/replaced.
HTH
Addam
2000 Grand Prix GTP Coupe (Best ET TBD)
1975 Monza 2+2 Sport Hatch (Best ET 12.93 @ 107.4)
Old 06-10-2009, 07:05 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Also, no adjustment for camber unless you add a camber kit.
Timeslip 08/12/06
AF Community Guidelines
