Old 06-08-2009, 05:06 PM
eaglebreath eaglebreath is offline
Bad Mass Air Flow Sensor ???
Does anyone know an easy way to test a MAF to see if its bad or not?
Also will this make your car stall out ? They are quite expensive. I would hate to buy one unless I'm sure.
thanks
1997 lesabre
Old 06-08-2009, 05:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Bad Mass Air Flow Sensor ???
A scan tool is the best method of testing. It will show air flow in terms of grams of air per second (gps), with a range from 3gps to 150 gps. The MAF sensor produces a frequency output between 32 and 150 hertz.
Old 06-08-2009, 06:06 PM
Also if it was bad..........wouldn't I get a code??
Old 06-08-2009, 07:58 PM
HotZ28's Avatar
AF Moderator Elite
You should! Do you have symptoms other than stalling; please give us more details of how & when the stalling problem happens.
Old 06-09-2009, 05:51 AM
usually dies when decelerating from 35-50 mph, and I don't have my foot on the gas. It just stops, but It will start right back up while I'm drifting.The only other symptom I can think of is I have to pump the gas pedal to get the car to start
approx. 35% of the time. I do own a DTC scanner and I am not getting any codes.
Any Suggestions??
Old 06-10-2009, 12:24 PM
rustbucket rustbucket is offline
I had one that was intermittent. Caused dying and run real rough. and eventually couldnt go at all. After starting and dying a few times it threw a trouble code that led me to the MAF. I unplugged it, and I could at least limp home. Opened it up (I thought I would have to order one, so nothing to loose), and I found a cold solder joint (actually a solder ball that was just laying on the contact). I soldered it and glued everything back together. It ran fine for a couple years till I traded the car.
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 06-10-2009, 01:25 PM
HotZ28's Avatar
AF Moderator Elite
Check the fuel pressure regulator vacuum line for raw fuel (gas)!
Old 06-11-2009, 12:16 PM
hotz28...........you nailed it. found gas in FPR
