Old 04-01-2003, 01:25 AM
SIvic SIvic is offline
changing cam
ok guys,
when changing a cam do I set all the timing to tdc?
line up cam gear with arrow on plastic cover, and crank pulley with second white arrow (the lonely marking)
then dissasemble the rockers and remove the cam, replace the cam at TDC?
someone plz help me out..
Old 04-01-2003, 01:34 AM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
First of all, its realy rude to make two posts about he same thing with the same content.
I will answer anyway. I feel like being nice Turn the crank to tdc then use the the edge of the head and line up the inner line(s) or the line on the right even with the surface of the the head (Were the valve cover would go) then put the belt back on and go from there. Also, it sounds like you need a helms manual... Who knows man, I could be a complete idiot blowing rainbows up your ass, or an idiot who thinks he knows how to work on cars?
Changed cams to HO and now P0016 mmsworker Dakota 1 07-05-2007 08:23 AM
Changing Cam Position Sensor---Any Suggestions? Hoags Montana/Montana SV6 4 02-14-2006 10:52 PM
General Information for All... Change Cam Position Sensor Hoags Montana/Montana SV6 0 02-14-2005 12:42 PM
H22a Type-S - Change cam gears + pulley kit?? Mr. Anderson Engineering/ Technical 0 02-15-2003 06:58 PM
Changing cam...!!?? SlowHatchGrL '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-15-2002 07:30 PM
