Old 05-29-2009, 07:47 PM
faction faction is offline
Engine Tubro Question
I was just curious about engines with a turbo, gas or diesel, vehicle
if they have a "turbo cooler"
if so which engines and why?
Old 05-29-2009, 08:04 PM
Mavrick14 Mavrick14 is offline
Re: Engine Tubro Question
Turbo's spin at tens of thousands of RPM, and this creates heat. They can be oil cooled from your engine oil or cooled from engine coolant. Without proper cooling, the bearings in your turbo will destroy themselves.
If your referring to intercooled, then that is a heat exchanger located in the air intake system between the turbo and the intake manifold. What it does, is remove heat from the incoming air. The cooler air, the denser, the more you can fit into the engine and the more power you can make!
Old 05-29-2009, 08:13 PM
Mainly I was wondering about diesels, like ford diesels, gm dodge etc turbo'd
do they have coolers?
or how are they cooled
Old 05-29-2009, 08:38 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Earlier diesels usually didn't have intercoolers. The Ford diesel didn't have one until 1999. The GM 6.2 didn't even have a turbo, but the 6.5s are intercooled. Some cummins have intercoolers, others don't.
Some turbos lately have been using engine coolant circulated around the bearings to cool them, but for the most part, many original turbos have a low enough stress level that they are just cooled by the oil circulating through the bearing.
Dragging people kicking and screaming into the enlightenment.
Old 05-30-2009, 12:15 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Let me add that they can spin to over 100,000 RPM.
