Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 05-22-2009, 06:24 AM
eric1h eric1h is offline
What tranny fluid?
It calls for GM Syncromesh, but what is everyone else using? I've used redline ATF in the past but figured i'd ask!??
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 05-22-2009, 06:46 AM
panozracing's Avatar
panozracing panozracing is offline
Re: What tranny fluid?
Promotion Powertrain, which I consider to be a top notch Tremec dealer told me dont try anything else in the TKO600 use the GM Syncromesh. I trust their knowledge.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-22-2009, 08:04 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Amsoil Synthetic Manual Synchromesh
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 05-22-2009, 08:25 AM
Panoz Paul Panoz Paul is offline
Greetings .... I went with all Amsoil products ; very happy ; talk w/ your local distributor for the Prefered Racer Program for a real discount !!!
Paul M. Winship / Chassis #37
Old 05-22-2009, 08:39 AM
Cobra4B's Avatar
I had no idea there was a preferred racer program... I have the preferred customer discount... I'll have to look into that!
Old 05-22-2009, 03:19 PM
g8rbob's Avatar
g8rbob g8rbob is offline
50-50 Mix of Redline MT-90 and Redline MTL in ours
edit - To answer questions below
MTL: 70W80 GL-4 Gear Oil (SAE 5W30/10W30 engine oil viscosity)
MT-90: 75W90 GL-4 Gear Oil that’s slightly heavier than MTL
http://www.redlineoil.com/products_g...7&categoryID=7
http://www.redlineoil.com/whitePaper/13.pdf
former part owner
GTWC
Old 05-22-2009, 11:52 PM
NZGTRA17 NZGTRA17 is offline
Redline MTL
Kel M
Panoz GTRA #17
New Zealand
Old 05-23-2009, 10:24 PM
PanozDuke PanozDuke is offline
Originally Posted by NZGTRA17 View Post
Redline MTL
What he say!
Mike
Old 05-30-2009, 09:56 AM
how are you guys filling the fluid? hand pump or are you removing the tranny tunnel?
Old 05-30-2009, 10:25 AM
I cut a hole in the tranny tunnel and used 4 threaded inserts and then made a cover plate with 4 screws. So I take the cover plate off and use a tranny funnel and fill away....
Otherwise I used to take the tunnel out each time.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 05-30-2009, 12:05 PM
David Eastman David Eastman is offline
I use a pump however I like Brians idea of a small axess panel.
David
Old 05-30-2009, 02:23 PM
Like Brian I cut a hole in the tunnel that lines up with the fill plug. I used a hole saw around 1.5" dia. Use a funnel with a piece of tube on it to fill tranny. Then just use black race tape over hole. Due to position you cant really see it.
Kel M
Panoz GTRA #17
New Zealand
Old 05-30-2009, 07:26 PM
great ideas! thanks!
Old 06-01-2009, 09:20 AM
Cobra4B's Avatar
Good idea on the access hole... I used a hand pump.
Brian B.
Old 06-01-2009, 12:18 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Damn, that is a good idea.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
