Old 03-31-2003, 11:45 AM
m3kidds's Avatar
m3kidds m3kidds is offline
Send a message via AIM to m3kidds
Looking for Component Speaks
i am looking for some components to replace my stock ones. right now i see a set of infinity reference for 100 on ebay. any opinions on their performance. also should i amp them or can i run them off my HU? i think i'm pushing 47wattsx4 from kenwood mp3 deck. thanks!
Uniquely Stock !!
Old 03-31-2003, 04:18 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Hu's don't really put out that much power .... I would put an amp to a set of infinity's
Old 03-31-2003, 04:22 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
pretty much any componant set you get should be amplified. That's my opinion. It's up to you. I have worked with those Infinity speakers and I really don't like the High pass in the X-over. It is real harsh and tend to get a bit raspy. I do how ever like the Alpine Type-R componants. They are really smooth and the high pass for the tweeter is real smooth as well. the mid bass driver when amplified hit nice and hard. I currently have Boston Acustic Pro's in both my Civic's. I really like them, but for much less money you can get the same if not better performance from the Alpine Type-R's.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 03-31-2003, 10:29 PM
m3kidds's Avatar
are the alpines really that good? the infinity's specs are a bit higher at 70wats rms compared to 50rms on the alpines. i was thinking bout getting the type r's but the infinity's specs caught my attention.
Uniquely Stock !!
Old 04-01-2003, 04:01 PM
Audio Guy
the difference between a speaker that can handle 50 watts and one that can handle 70 watts is not a big deal.
Old 04-01-2003, 06:50 PM
91EF3ZC's Avatar
AF Premium User
the differece is very noticable
Old 04-02-2003, 05:43 PM
m3kidds's Avatar
hmm.. well i guess i'll go with the alpines.. do they fit right in a 97 civic w/o too much hassle? and i'll def. amp them cuz i have 2 free channels to work with from my amp. i'm guessing pioneers sound crappy too right?
Uniquely Stock !!
Old 04-02-2003, 08:45 PM
91EF3ZC's Avatar
AF Premium User
pioneer doesn't sound crappy, but they run out of steam, if you know what I mean. They will start to distort sooner. The rears will drop right in, I belive it is a 6X9. the fronts need to be cut in. the door panel needs to be cut out to fit the bigger basket of the speaker. it is well worth the work.
Old 04-03-2003, 02:12 PM
strodda strodda is offline
not only width, but check the depth clearance. i bought a set and i had to return them because i couldnt fit them in. if i mounted the speakers the way they were supposed to be, the window would hit if i rolled it down.
Old 04-03-2003, 02:59 PM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
this can be very true. i had to heavily modify my doors to allow for install of my Infinity Perfect 6.1 set, worth it tho.
Old 04-03-2003, 03:26 PM
91EF3ZC's Avatar
AF Premium User
I just did a set of Type-r's in a 99 Si. , it cleared the window.
Old 04-03-2003, 05:34 PM
m3kidds's Avatar
i'm guessing the 97's and the si's should be the same door set up right? also i was looking at the rockford fanatic series. how are those compared to the type r's?
Uniquely Stock !!
Old 04-03-2003, 07:57 PM
91EF3ZC's Avatar
AF Premium User
About the same, both are very good.
The door panels on the two door civic is the same as the 99-00 Si.
Old 04-13-2003, 11:20 PM
OneSikCRX OneSikCRX is offline
Send a message via AIM to OneSikCRX Send a message via Yahoo to OneSikCRX
the alpines are a very good sounding speaker and they are not too expensive, only like 25o a pair, but if you want real volume that is still clear and awesome get the boston pro components, just the 6.5 handles 200 watts, then theres the tweeter, i have them hooked to a 90x4 rms cutting edge car audio amplifier and they are sooo awesome, but you cant be affaid to spend a little money
Old 04-14-2003, 04:37 PM
m3kidds's Avatar
i just might go with the alpines cuz i seen them for 130 on ebay. i'll be pushing them with a rockford 600 4 channel. i hope that should be enuff.
Uniquely Stock !!
Installing Phoenix Gold Octane-R Component Speaks vinnym86 Car Audio 0 09-30-2005 01:15 PM
Looking for a car looking for speed and looks evinh10 Car Buying Q&A 4 09-03-2005 01:14 PM
looking for '68-'70 Charger, looking for parts for '36 Chevy ndoerr Engineering/ Technical 0 08-26-2005 12:31 PM
Looking For Good Component Speakers l2ice rocketz Car Audio 1 02-12-2004 04:58 PM
