Old 03-31-2003, 01:50 AM
src21k src21k is offline
ecu swap
i have a '91 crx hf i was wanting to put in an ecu for a '89 integra
my question is this.
will this hurt me alot or will it actually help me a little
Old 03-31-2003, 02:00 AM
91civicDXdude's Avatar
It could possibly help AND hurt. It might help in the performance department because of a more aggressive fuel curve, but the 7800 rpm rev limit on the integra (PG7) ECU is most likely higher than your HF engine was built for, considering the HF rev limit is about 5400rpm or so. If you were to use the PG7 ECU, you might want to think about shaving some lead off your foot becaue too many times of revving it past 5800rpm or so and you can say bye bye to your engine.
Old 03-31-2003, 10:53 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Swap it with an si head and u'll be str8.
Old 06-20-2003, 08:59 PM
HyperHf HyperHf is offline
Send a message via AIM to HyperHf
95 civic head on crx Hf???
[b] [size=3] I've got a 91 CRX HF and I've got the opportunity to put a 95 Civic EX SOHC V-Tec head on it. Can I do that??? Is it safe on the 1.5L Hf block? I'll be getting all the wiring and exhaust manifold too.
Old 06-20-2003, 09:04 PM
GTA's Avatar
GTA GTA is offline
Whee..
why did you bump a 3 month old thread for this??? why not just start a new thread...
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
ecu swap? from honda to integra brokenpgm-fi General Discussion 4 02-16-2004 01:55 AM
ECU Swapping? fsthonda12 Let's get Technical! 4 01-20-2004 06:04 PM
ECU swapping for Performance natitus86 Engineering/ Technical 2 01-08-2004 11:57 PM
ecu swap????? Crxce '88 - '91 Civic | CRX | Wagon | Shuttlee 9 03-18-2003 03:46 PM
Ecu swap question!! mellowboy Engine, Transmission and Drivetrain 1 01-31-2002 12:35 PM
