Old 03-18-2003, 12:50 PM
Crxce Crxce is offline
Send a message via AIM to Crxce
ecu swap?????
I have a 88 rex dx doing the mpfi swap this weekend hopefully what is the best ecu i can get, out of what car? i know there is a couple i can use but is one better than the other? thanks
Old 03-18-2003, 12:56 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
the pm6 out of an si...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 03-18-2003, 02:17 PM
aces1980 aces1980 is offline
or u could use an ecu from a 89 teg i think that'll work too. not to sure. but it works on my si
Old 03-18-2003, 02:20 PM
91civicDXdude's Avatar
okay here goes, this will set the record straight
the PM6 is the best ECU to use with a non-OBD engine. sure the pg7 integra ecu supposedly has better fuel maps and such but realize that eh pm6 was made for an MPFI single cam engine whereas the teg was made for a dohc engine.
Also, with the pg7 ecu, you have a 7500-7800 rpm rev limit and its too tempting to rev it that high just because. but what this will do is give you a little fun thing called floated valves and you will blow your engine up.
just my $.02
Old 03-18-2003, 02:42 PM
i nerver thought of that. Thanks for the info. I think i'll just take my off and replace it with my old pm6 good thing i didn't sell it?
Old 03-18-2003, 03:29 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
The pm6 form a '91 Si is the best one to get.
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
a d series engine is mechanically stable up to 7650 rpm and safe up till then. With a stock cam, 7800 rpm is no problem with the exception you may lose some life to your valve train in regards to about 130,000 miles instead of 150,000. My $.02
Old 03-18-2003, 03:39 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
You'd be str8 with pm6 ecu
Old 03-18-2003, 03:44 PM
a guy at the junk yard is going to locate a ecu for me and when he does how do i know if its really a pm6 does it say it on the ecu?
Old 03-18-2003, 03:46 PM
mellowboy's Avatar
IT'll say pm6 on the bar code tag thing.
