Old 03-30-2003, 10:20 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Amp Gauge question
ok i got a Sunpro 2 1/2" Amp gauge and wanna hook it up but dont have anything other than the gauge cuz I stole it from my brothers cab he rolled lol, i'm gonna make my own custom mount prolly but i need 2 know how 2 hook this up first so I can monitor my battery to make sure i'm keepin a good charge and stuff, so do I just run a wire from the positive and negative on the battery to the back of the gauge? or is there more 2 it? and what kind of wire do u suggest using? because i have a bunch of left over speaker wire i could use if I have to
any help would b great! thanx guys
Old 03-30-2003, 06:14 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
ok 1st things 1st you gotta shut off the flux capacitor, then you take a screwdriver and the wire and lay the wire on the battery terminal and smack it with the screwdriver and your all set :smoker2:
2002 Acura TL Type S
1991 Honda Crx Si
Old 03-30-2003, 07:24 PM
1PhatCX's Avatar
so i take it, all i do is hook it to the battery lol
Old 04-01-2003, 03:20 PM
1PhatCX's Avatar
bump
so can I use speaker wire 2 connect it 2 the battery?
Old 04-01-2003, 04:09 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
correct me if i am wrong but if u hook it directly up to the battery the gauge will always be runnin right ? instead of off when you turn off the car
Team Lonely Drivers
Old 04-01-2003, 04:15 PM
1PhatCX's Avatar
yea thats what i was thinkin,
i was gonna connect it to a toggle switch so i can turn it on after the cars on but i still need 2 know what kinda wire 2 use and how 2 hook it up, cuz i dunno if it goes to the battery or the Alt.... please help everyone!!!!!!!!!!!!!!!!!!!
Old 04-01-2003, 04:16 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
Hey man, ill sell you my oil pressure gauge...10 bucks!or cheaper
PeacE
Old 04-01-2003, 04:19 PM
1PhatCX's Avatar
lol, i already got one i wanna get ridda haha
tryin 2 talk a kid at school into buyin it lol
Old 04-01-2003, 04:47 PM
Stali08's Avatar
haha, thats awesome.
PeacE
Old 04-01-2003, 04:55 PM
mightytexn's Avatar
mightytexn mightytexn is offline
Send a message via AIM to mightytexn
I think the volt gauge would go to the alt b/c when the car is running, the battery is pretty much useless, unless you have an amp hooked up to it.....once the car starts everything runs off of the alt.
I'm Jordan
My car is the ugliest one on this board
Old 04-01-2003, 05:07 PM
my post didnt mean hook it up to the battery i was just bein dumb sorry for the misunderstanding if there was one, im confused
1991 Honda Crx Si
Old 04-01-2003, 05:49 PM
91civicDXdude's Avatar
how about hook one side up to a key switched circuit in the fuse box so it only comes on when the car is on like all the other gauges
Old 04-01-2003, 10:07 PM
OneSikCRX OneSikCRX is offline
Send a message via AIM to OneSikCRX Send a message via Yahoo to OneSikCRX
yeah the autometer instructions say to hook to a switched wire like one from the back of the ignition switch and the other to a very goo engine ground, it even sais to run it through the fire wall to get to the block for a ground, i think thats a little overkill. but hey thats y they get payed the big money
Old 04-02-2003, 07:10 AM
1PhatCX's Avatar
yea i was thinkin the same thing, do u know what wires 2 connect it too on the alt?
Old 04-02-2003, 09:10 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Quick wiring lesson. The wire to the alt is always hot. Look under the hood and follow the wire from the battery to the underhood rfuse box. The alt wire is on the same block as the battery wire, so the battery will see the same power as the alt, which should be about14.3-14.4 volts. Take regular shielded wire, not speaker wire, safety first, and put a switch on it. By wioring it into the igintion switch, you are dawring power from other parts that need it and your car amy shut off intermintly.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Volt gauge riccbhard Camaro Discussions 0 01-15-2006 12:24 AM
VOLT Gauge Lowers in Reverse..? solaris=amazing Engineering/ Technical 6 01-18-2005 04:03 PM
Voltmeter/volt gauge installation AccordCoupe666 Accord/TSX/Accord Hybrid 2 01-02-2005 08:58 PM
Volt gauge/ '05 dass Silverado 3 12-05-2004 09:19 PM
volts gauge dosent work bc4g '88 - '91 Civic | CRX | Wagon | Shuttlee 5 11-23-2002 11:27 PM
