Old 11-23-2002, 12:38 AM
bc4g bc4g is offline
volts gauge dosent work
learning electricial in school so i was playing with a test light and i touched it pos. side of volts gauge while car was running it sparked and ot dosent work ANY IDEAS IF I FRIED IT? pos. was hooked into fuse bx under dash pannel there is 3 places to plug things in with a terminal with a - I put it in the far left and now test probe shows no power there at all. ANY HELP IS GREATLY APPRECIATED
thanks
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 11-23-2002, 12:46 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
well i used to install stereos and alarms my company said NOT to use test light cause it can set off the airbags ...use a meter
something about it giving enough (very little) power to set off the bag.
maybe the gauge is really sensitive
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 11-23-2002, 10:03 AM
Thanks for the reply but what i should of said about the gauge is that its one of those autometer ones I had in my gauge pod.
I hooked it straight to the batt. and it dosent work at all
Thanks again
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 11-23-2002, 10:04 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Did you check all your fuses???
My other ride..... is YOUR MOM !!!!!!
Old 11-23-2002, 02:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
so are you studying car electrical or house electrical ? yeah i used to work as a house electrican. if that gauge has a fuse then you probably blew it or blew the whole gauge out. you should hook it up first then test it. i blew alot of fuses learning that the hard way.
Old 11-23-2002, 11:27 PM
car electrical --I also found out my radio dosent work
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
Cig Lighter Dosent Work Anymore?? kyle5077 Escort 1 09-01-2005 10:41 PM
95 jetta speedo dosent work nikunj '91 - '96 1 09-04-2004 12:11 PM
Parking break dosent work. joshsworld21 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 07-31-2004 08:51 PM
my tach dosent work when the lights are on bc4g '88 - '91 Civic | CRX | Wagon | Shuttlee 10 10-20-2002 11:38 PM
