Old 04-28-2009, 05:52 PM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
Magnetizer?
I just picked up a 2002 Silverado/1500/4x4. After further inspection, I noticed it had "Magetizer" magnets on the coolant, air and fuel lines. I did a little research and it's supposed to be a fuel saver etc. Anyone have any experience with these things?
Also, the truck runs great and is a solid truck. The only thing it needs is tires. Any recommendations?
Old 04-28-2009, 09:36 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Magnetizer?
somebody got suckered into spending money they didn't need to! Not you, the previous owner!!
Old 04-28-2009, 10:55 PM
bigbadram51 bigbadram51 is offline
Re: Magnetizer?
If you cross your fingers and shut your eyes real tight...wish harder than you've ever wished in your life........They still dont work...LOL!! Previous owner must have lost a bet.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 04-29-2009, 01:19 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Magnetizer?
I recommend you remove them, you'll save a few ounces of weight and they make great refrigerator magnets!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 04-29-2009, 03:34 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: Magnetizer?
check if you do not have magnet underneath the gas pedal. so it does not draw it too much down towards the floor.
now, I'll aplogize for myself being goofy, and for the rest of the posters. It is a very serious question. No, they will do squat on power/mileage thingy.
IT IS NOT WHAT YOU DRIVE, IT IS HOW YOU DRIVE. (J. Clarkson, Top Gear)
Old 04-30-2009, 10:25 AM
Streetwise's Avatar
Re: Magnetizer?
Lmao! You guys are funny here! Good stuff. The funny thing is, it also had those electrical rust preventers. Wires everywhere. Ripped it out 10 seconds after I opened the hood. I guess the previous owner had some superstitions.lol.
Old 05-03-2009, 03:58 PM
ukrkoz's Avatar
Re: Magnetizer?
well now, there is a legit device, used by car manufacturers, that is electrical in function and is connected to the body. rust, or oxydization, requires specific polarity for O2 to interact with Fe ions. that device is changing that polarity to the point that electrochemical reaction, called rusting, just does not go.
it's been around since early 90s, i believe, and was used, if memory does not fail me, on Hondas at least. so, it might have been legit doohickey.
now, if you want to see REALLY weird stuff, look into joe cell. that is some serious magic, mah man
http://www.youtube.com/watch?v=A-q6H...om=PL&index=31
Old 05-04-2009, 12:37 PM
Re: Magnetizer?
I posted a thread a long time ago, that is gone now. But Popular Mechanics did a feature on all of those fuel saving gizmos. From the magnetizers, the "tornado", water injection, ionizers. None of them had any positive effect on fuel mileage, one of them, if I recall right the "tornado" actually caused a drop in MPG
3" PA Body Lift
Covermaster Top
Old 05-04-2009, 03:42 PM
j cAT j cAT is offline
Re: Magnetizer?
on your tires ...I have used C rated tires on my 1500...these give a good ride...the E rated tires for 2500 are too stiff..
firestone steeltex 245 75 r16 LTX tires C load rating came with special order when new 90,ooomi...replaced with same 3years ago now 120,ooomi plenty of tread left, and a smooth ride also not expensive tire..
rotate every 10,ooomi....
Old 05-27-2009, 08:53 AM
Streetwise's Avatar
Re: Magnetizer?
Much like my T-Blazer, it rides very well. I was suprised. The tires I have now seem to have decent tread left, but they're noisy, cause vibration, (they are balanced) and when you run your hand over the tire tread, you can feel spots where it's raised up. I don't know if it was from not rotating them, or what. I will look into the tires you mentioned, thanks for your advice. Do you know if you can put a bigger tire on?
Old 05-27-2009, 01:35 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Magnetizer?
Sounds like the previous owner would have been a good customer of those snake oil salesmen of that roamed the frontier in the 1800's
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 05-27-2009, 03:33 PM
jdmccright's Avatar
The RustBuster
Re: Magnetizer?
I have seen a few ICCP (impressed current cathodic protection) systems marketed to protect older, less well preserved vehicles from rust. I don't know anything about their true usefulness, but working in the field they may be of some advantage to them if you're in water alot...boat launching or mudbogging, or exceptionally high-salt use regions. A couple of zincs bolted to the inner frame rails would work too.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 05-28-2009, 06:11 PM
Re: Magnetizer?
the only place I seen this is on boats...keeps the prop from disintergrating...also if it has prop shafts keeps them from corrosion in salt water..they also will reduce the engine coolant [sea water] portion from corrosion...esp. if its a closed system...with heat exchanger...
Old 05-29-2009, 11:05 AM
Streetwise's Avatar
Re: Magnetizer?
I don't buy into electrical current preventing rust. I've worked on many cars that had the systems on them, yet they were still a pile of rust you needed a tetanus shot to touch. How much current would you need for there to be any significant prevention? Probably more than the vehicles 12 volt system would allow. Gimmick at best.
Old 05-29-2009, 04:13 PM
Re: Magnetizer?
when two metals like as an example copper and steel touch each other in a salt solution electrons flow..this then causes the metals to disintergrate....
my aluminum swimming pool after 10 years all the metal support pads where the pool ground wires where connected melted the aluminum TO dust...the other pads where good....
unless you drive your vehicle in the ocean or in a very salty environment this would not be that effective...sealing the metal sufaces has worked for me..mineral based undercoatings ...
this is why also the coolant system must use distilled water and be serviced whenever the coolant starts to get discolored as this is the metals getting into the coolant ...
