Old 04-22-2009, 02:34 PM
all power all power is offline
want more pep for cheap?????????
got a 99 gtp w 81000 on her she runs great but looking for a little more. is there anyway i can get more by doing simple things to her? cooler plugs/ t-stat/wires/coil pack/T.Bspacer/i plan on getting news pipes from the cat back w/dynomax mufflers and im runnin 93-94 and sometimes 110 octane in her to clean her out.and tips/tricks would be helpful..............thanks
Old 04-22-2009, 02:53 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: want more pep for cheap?????????
well...if your getting the exhaust done, you might as well buy a Ubend delete and have that installed.
Old 04-22-2009, 04:18 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Free up the exhaust with a hi-flow cat and u-bend delete, then add better induction with smaller S/C pulley (3.5" or 3.4") with supporting mods including reprogrammed PCM, 180 t-stat and colder heat range plugs. If you want to go further, then you're going to have to spend bigger money for things like headers, true cold air intake (not one of those cheesy cone filter and polished intake tube pieces of junk) or open up the engine and install longer ratio rocker arms, beefier valve springs, etc.... I would also strongly suggest installing a trans shift kit to help it handle the higher power levels.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-23-2009, 09:52 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
what kind of power increase would you be looking at with the u-bend delete, aftermarket cat-back, reprogrammed PCM, new plugs, and say a 3.5 or 3.4 pulley, and whatever other supporting mods that are recommended?
Old 04-24-2009, 10:50 AM
richtazz's Avatar
That will put you close to 300hp or maybe even better. Hopefully one of the modded
GTP owners will chime in with their personal gains.
Old 04-24-2009, 05:08 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Not sure I've got that much Rich. But I dont have a cat back.
I'd say maybe 280 topps.
I've never had it dyno'd (I'm afraid I'd blow the trans)
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
