Old 04-04-2009, 08:04 AM
hdkiwi hdkiwi is offline
1999 pa BCM ????
The BCM on the PA needs to be replaced but I am having a hell of a time matching the part no. on the module with what what i keep getting from pats suppliers. part in care has a blue connector part from supplier has pink.
were there 2 differint BCMs in 99?
part # I have is 16832774 located behind glove box
thanks
Mike
Old 04-04-2009, 10:53 AM
imidazol97 imidazol97 is offline
AF -Advisor
Re: 1999 pa BCM ????
thanks
Mike
The AC part on rockauto.com is ACDELCO Part # 9385329 {#09385329}
MODULE,BODY CONT
But for Cardone they list two different reman modules. One shows from 1997-2005 and the other shows 1997-2002.
You may need to find a dealer to ask about what the correct replacement is.
rockauto.com, buick, 1999, parkavenue, electrical, body control module
Old 04-04-2009, 10:55 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Also, keep in mind the BCM module will need to be initialized or programmed by the dealership.
And to the OP welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
Old 04-06-2009, 09:36 AM
thanks ...........and thats a roger on the program.
The AC part has the pink connector (which doesn't key to the blue one(mating connector) in the car.
Old 04-08-2009, 06:34 PM
hawku8 hawku8 is offline
Send a message via Yahoo to hawku8
best way to get correct part is to supply last 8 of vin to a GM parts counter. there may have been mid year changes.
Old 04-24-2009, 01:55 AM
happydog500 happydog500 is offline
fyi, I had a few people say my 97 BCM needed to be "programed". One guy said it didn't. One Dealer said it did, the other in my area said it didn't.
The place where I ordered it (internet) said they don't need to be programed.
I bought it on that advice. It was Plug and Play, works without programing. One dealer was going to charge an hour, when it didn't need to be.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 04-24-2009, 06:25 AM
BNaylor's Avatar
Was it new or used? The requirement is specified in the GM service manual under BCM Programming/RPO Configuration. It states the BCM will not function properly if the Setup New BCM Procedure is not performed. Therefore it is supposed to be applicable to new BCM modules off the shelf that were never installed or originally programmed before delivery of the vehicle.
Timeslip 08/12/06
Old 04-24-2009, 05:16 PM
Brand new, never installed.
New Balance 662
Trek 8000
