Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 03-29-2009, 12:26 AM
d768 d768 is offline
where to place the jack?
hey guys. i want to check on my front brakes. i have a hydraulic hand jack(the one with the lever,on 4 small wheels). where do i place it? im afraid to bend something under there. on my 4x4 it was easy...even used a piece of wood to prevent denting.but on the chevy im really afraid to mess things up.lol.
thanks a bunch!!!
Old 03-29-2009, 12:07 PM
Re: where to place the jack?
found it,thanks.looked under, saw the frame. i took an old tshirt folded it several times.put it on the jack. remember to position the jack at a 90 degree angle with the car because itll want to move forward a bit when you lift it high(er).
breaks look ok.
the left front wheel moves a bit on a horizontal axis when i pull on it, nothing on the vertical.what could it be?
Old 03-29-2009, 11:33 PM
H1HUMMERMAN's Avatar
H1HUMMERMAN H1HUMMERMAN is offline
The play in the front wheel is a bad tie rod. whether it is the inner or the outer, you will have to look to find out.
Old 03-29-2009, 11:54 PM
thanks for the reply. if it doesnt move much, does it mean its not serious enough to run down to the shop first thing in the morning? my work schedule is a bit crazy.ill miss work if its serious.
moving the wheel left right it moves a bit. on the street i havent noticed much or anything, the steering wheel doesnt jump around or vibrate.
Old 03-30-2009, 10:54 AM
rockwood84 rockwood84 is offline
a floor jack on wheels is dangerous to use if not on a surface so it can roll as you lift.if your not using it on concrete as i sometimes do .use a piece of 1/8" sheet steel at least 8" wide by 24" long and this will let the floor jack work properly. and do not under any circumstances get under the vehicle with out blocking or useing jackstands to support the vehicle.
Old 03-30-2009, 11:00 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
That is a common issue with these vans. I've replaced my share in both Ventures that I've owned. They tend to wear out quicker than other models, either design flaw or poor quality item .
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 03-30-2009, 04:40 PM
A little bit of play is no emergency. Just make sure you don't forget about it. If that part fails, you will have pretty much no steering which obviously can cause some major problems.
Old 03-30-2009, 11:05 PM
wow. i tought i was unlucky. had a 2002 before, didnt check it on that one but i remember someone telling me to look for vibrations in the steering wheel when going over holes or rough surfaces..i remmeber having way more with that one than the 98 i got now.
thanks
