Old 03-27-2003, 03:16 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Exclamation oil question?
Ok saturday i'm changing my oil and normally for my car is recomended 5W30. well i was talking to this guy on what brand should i use and he recomended redline which i understand is used in racing. he also recomend to use 10W30 which is slighty thicker and should better if i push harder my engine especially in the summer when the engine would heat better.
also i undesrtand that if i would get Mobil 1 which is good oil but even the fully syntetic version is not 100% pure syntetic while the redline is.
So what do you guys recomend? use the redline(which cost 9$ a quart) or mobil 1 which i still have to find out how much will cost (obviouslly cheaper though)
also should i go with 5W30 as in the manual or use 10W30?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 03-27-2003, 04:08 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
At high temperatures, there is very little difference between the 5w-30 and 10w-30 oils, at least in regard to Newtonian viscosity. It's in the extreme pressure scenarios that multigrade oils may have trouble, as far as I know.
Under extreme load conditions, at higher engine speeds (high pressure, high shear), natural 5w-30 may break down slightly faster than the 10w-30 does, and the 10w30 would probably provide better protection. A straight SAE30 would be even less prone to this breakdown.
If you believe the "company line" of synthetic oil manufacturers, the above concerns do not necessarily apply to synthetic oils, which supposedly can resist shear breakdown much better than the dead-dino variety can.
I would personally trust Mobil-1 more than a "specialty" oil company (since the specialty company probably gets their oil from a big-name company anyway). I don't have any specific information to support this prejudice, so your own opinion is at least as good as mine.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 03-27-2003, 08:41 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I use Redline tranny fluid and the oil for my rear end. But those don't get change often most people never do until something goes wrong. I like Redline products but at the prices per quart compared to the gain they suggest 5-10hp is it really worth it? I don't choose to think so. Also you need to change your oil frequently... expensive proposition
Also I think the person suggesting the thicker oil, used this theory. The thinner oil you can use before gettin blow by the more power you free up. So if Redline gains power it's probably thinner. So bump up a wieght to be on the safe side.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-28-2003, 10:11 PM
Neutrino's Avatar
Yaya Master
thanks both of you for your advice.
In the end i decided to go with mobil 1 fully syntetic. I mean everyone says that is awesome and i found 6 quarts for only 23.39$ in Costco(love that place) i woul've payd 45 $ for 5 quarts. So i guess is just not worth it.
(\__/)
Old 03-29-2003, 07:48 PM
911GT2 911GT2 is offline
You'd be amazed at how little difference there is between cheap and expensive oils.
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
2006 slk350 - oil & filter change question ninja650R SLK 6 07-17-2009 09:00 PM
Oil....Question about oil Shinigami2x4 Camaro Discussions 7 08-04-2004 11:26 AM
Oversize Oil Filter & Synthetic Oil questions big_john Tacoma 9 04-10-2004 08:43 PM
Oil Question forum15 Engineering/ Technical 8 06-21-2002 11:51 AM
Oil question... Myxtreme1 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 2 02-27-2002 09:07 AM
