Go Back   Automotive Forums Car Chat > Mazda > MX-5/ Miata
Old 03-27-2003, 10:07 AM
ANNAOSSENFORT ANNAOSSENFORT is offline
Unhappy check engine light code
The check engine light has been on on my '99 Miata for more than a year. The guy at the Shell station was nice enough to check the code for me, but the dealer won't tell us what the code means. Does anyone out there know what P1135 error code indicates? Much appreciated. -- Anna
Old 03-27-2003, 11:16 AM
Talking
I'm insanely proud to report that I answered my own question. And I want to turn everyone else on to the way I did it: If you go to www.obdii.com/codes.asp, you can enter the make of the car and the code (in my case P1135), and it will spit out exactly the cause of the error code. Mine was the heated oxygen sensor. The beauty is that I didn't even have to call the dealer to get this information, and can instead keep in business the handsome, affable Greek guy down at the corner service station! - ako
Old 06-15-2004, 12:42 PM
zelgini zelgini is offline
I'm also having trouble with the check engine light going on and off - sometimes the engine isn't running well, sometimes it is. The code the service folks get is "random misfire" and can't seem to find the cause of it. Anyone have any clues?
Old 06-19-2004, 11:55 AM
SOULofMAZDA's Avatar
SOULofMAZDA SOULofMAZDA is offline
Send a message via AIM to SOULofMAZDA
Re: check engine light code
I went to that website and it doesn't offer anything for miata only for domestic cars?
2001 Mazda Miata Mx-5 SE
Old 07-14-2004, 06:52 PM
Sparky Lang Sparky Lang is offline
What year is your Miata? The 1999-2000's had a batch of bad coil packs (the ignition coils that the spark plugs connect to.) It is easy to replace yourself, but costs about $220. If you let the problem go on too long it will destroy your catalytic converter.
Old 01-10-2005, 12:54 PM
baxter65 baxter65 is offline
How does one know what the code is? Does it take a mechanic, diagnostic equipment etc. Sorry - I'm not to savvy with cars, but my engine light goes on for a few days about once a month. So far I have just ignored it because it soon turns itself off again.
Old 01-12-2005, 08:25 PM
Ken Downs Ken Downs is offline
Question EGR valve causes check engine light
My 1999 Miata check engine light stays on all the time. If the code is reset the light stays off for a few days and then returns. Autozone says it is a problem with the EGR valve. I removed the valve to check for carbon build up and clean it. Reset the codes by disconnecting battery. Of course the light came back on after 3 days. But long enough to pass emissions test!! Anyone heard of problems with the EGR? They are $250, I would like to avoid buying a new one. Sometimes the car will idle rough thought it might be related to the coil problem described in the other post. Any connection to the EGR?
Old 02-02-2005, 12:35 PM
Bill4kath Bill4kath is offline
Re: EGR valve causes check engine light
I got 2 codes today I just pulled. They are P0303 and P0420. The P0303 says cly. 3 misfire detected. The P0420 says catalyst effeciency below threshold (bank 1). Could this be a bad coil pack and that is what's making the 420 code pop up?
Old 02-03-2005, 09:27 AM
Bill4, your codes are exactly what happens when the coil pack is failing. If the rough running continues it will wreck the catalyst, that is what causes the P0420 code.
Old 02-03-2005, 02:03 PM
If changing the plug wires does not fix the problem, you probably need a new coil pack. The part is expensive (around $230) but is not difficult to change. This should fix the misfire problem. However, if the 420 code remains you may need to have the catalyst replaced. Fortunately this is a covered part under the 80,000 mile emissions equipment warranty.
Old 02-04-2005, 01:08 PM
Hey thanks, I did get the coil pack today. Going to install it in a few. Also, thanks for the heads up on the 80,000 mile warranty on the catalyst.
Old 02-04-2005, 06:17 PM
Before I installed the ignition coil pack, I bought a set of NGK wires for it. And, that was the problem. Luckily I was able to returm the coil pack. Thanks for all the help.
Old 11-01-2005, 07:56 PM
yongsu yongsu is offline
If the coil pack is bad, wouldn't the ecu code show two misfiring codes? Isn't there dual coil on the miatas? I think it is a single unit, but has two coils.
Old 11-03-2005, 09:47 AM
mazdatech177 mazdatech177 is offline
youll get p0300 for a coil going bad, it is a two plugs per coil setup.. when the pcm detects more than 1 misfire it throws a "random misfire" code p0300.
Old 11-04-2005, 11:42 AM
Post
I have a 99 miata which had to have cat replaced (ECU P0421). Just bought it..... The dealer asked me if I had any misfire problem, which probably caused the cat to go bad. They suggested that I get new coil pack ~$400 replaced. I talked to the previous owner, and he told me that he had problem last year (running really rough) where he had to replace crankcase position sensor ($350). Could CPS have been the problem? Should I be worried and replace the coil pack? I know that 99 supposedly had faulty coil pack, but replacing something that works well for ~400 is stupid. What percentage of the 99 had bad coils? Why isnn't Mazda recalling coil pack like they did with the Protege?
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
