Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-15-2009, 04:37 AM
frootlooprules frootlooprules is offline
air bag and electrical questions. 93 CV.
#1 What is airbag code 12?
#2 Running lights (tail, parking) and dash lights not working except back in January when the outside temp dropped below zero, then they worked 'till it warmed up outside. I put in an aftermarket switch about 2 years ago because of the same problem. Should I focus my search elsewhere, or are H/L switches a known problem.
Tanx, in advance for your help! Have a couple more irritating little problems, but will open them to discussion after I fix these.
Old 03-15-2009, 11:16 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: air bag and electrical questions. 93 CV.
Code 12 is for low battery voltage to the module. Check all cabled and connections to be sure they are clean and tight.
Sounds like your lighting is due to a wiring concern also. When the wires get cold, they will "shrink" a little and could cause a loose connection to become good again.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-19-2009, 06:36 PM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
I agree with "Way2Old"
I would also check the fuses. Often a blown fuse in the airbag circuit will also cause a code 12. If your system has deployed, it will blow that fuse and there are multiple items you need to check
Check out this website.
http://www.airbagsolutions.com
The purpose of this website and company is to help people diagnose and repair airbag problems themselves without taking them to the dealer (if possible). It offers all the photos and data you need to understand your airbag system, read the codes and reset the light. It’s a pay site, but it certainly is worth the money ($14.95 for 1 day full access)
There’s a place to check if your car is listed on the home page
http://www.airbagsolutions.com/vehicles_list.aspx
This is quite an extensive website with pictures, descriptions and factory fault code charts as well as a working demo @ http://www.airbagsolutions.com/demo.aspx that shows just how easy these repairs can be.
Lots of insurance companies and body shops use this site for the information they need to repair your car.
I hope I’ve helped you
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Tags
airbag codes , electrical , headlight switch
