Old 03-13-2009, 09:56 AM
racefan978 racefan978 is offline
94 camaro z28 lt1 cooling problem
My car is not cooling properly. My over flow jug stays full but my radiator does not it is not taking the antifreeze from the jug.I have replaced water pump and thermostat and i still have the problem.Can anyone help me please.
Old 03-13-2009, 08:51 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 94 camaro z28 lt1 cooling problem
How can you tell the radiator isn't full?
Dragging people kicking and screaming into the enlightenment.
Old 03-14-2009, 09:00 AM
When i let it cool down i take the cap off.The antifreeze level is low.I was messing with it and found that when i mash the gas antifreeze blows out the top of the fill jug(catch can,overflow.
Old 03-14-2009, 12:31 PM
curtis73's Avatar
I didn't think that 94s had a radiator cap... I thought they just had the surge tank cap.
The only thing I can think of is a clogged heater core or clogged heater hoses. If they follow the same cooling path as I think they do, the water goes to the heater core, then back to the radiator via the surge tank.
Old 03-14-2009, 01:48 PM
I was thinking along that line but i wanted some advice i don't know everything.I had a friend tell me it might be the radiator cap.what do you think.Thank you for the advice I appreciate it.I will let you know what happens or i find out.
Old 05-29-2009, 08:37 PM
Mavrick14 Mavrick14 is offline
Replace your rad cap and pressure test the cooling system. The cooling system should build pressure when hot, and when it cools down it should create a vacuum and suck the coolant from the overflow back into the motor. Your cap controls both the pressure relief and the vacuum return.
