Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-09-2009, 12:09 AM
Amanda'sMarquis Amanda'sMarquis is offline
Help! No brake lights an cant get out of gear
If anyone can help id appreciate it, i have a 1997 mercury grand marquis, the problem is occasionally ill have no brake lights and cant get the car out of park. i sorta know the problem has to do with a switch or plug that goes into my brake peddle arm, im not sure what its called and how to go about finding/fixing it.but the few times its happened this week ive wiggled this part and then it would work but now its completely not working
im female and a lil auto-illiterate (i know basic maintenence thats it)so please put any response into simple explainations Thank You
Old 03-09-2009, 07:26 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Help! No brake lights an cant get out of gear
It is not really a hard job to do. The following link has written directions. First thing is to check the connector to be sure it hasn't broken or burned causing the problem. If connector is OK, replace the switch. Click here for info.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-13-2009, 07:29 AM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
The quickie fix to keep you going is to turn the key on (do not start the motor) then put the shifter in neutral and start the motor, This will allow you to shift into drive and get you going. Keep in mind that you probably won't have any brake lights. The actual directions should be in your owners manual if you have one.
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
