Old 03-08-2009, 01:40 PM
SsHaDyGt SsHaDyGt is offline
PLastic side skirt coming off
Hi all,
The plastic side skirt on my GTP is starting to come off.
I tried to use 60 second apoxy to stick it back on but it didn't hold up.
Does anyone know of anything else that I could use on it?
Thanks
Andy
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 03-08-2009, 10:26 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: PLastic side skirt coming off
What side skirt are you talking about? You mean the ground effects towards the bottom of the doors and on the rocker panels? Or the black plastic pieces held in by clips that are in the engine compartment by the front wheels?
If its the ground effects.... 3M double sided tape maybe?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-09-2009, 02:06 PM
The ground effects.
The plastic that is at the bottom of the door and the rest of the body (2 door).
I guess I could try the double sided tape, nothing stronger?
Thanks
Andy
Old 03-09-2009, 11:51 PM
tblake's Avatar
In God We Trust
Try out some 3m double sided tape. They made a permemant kind that was next to impossible to peel off once stuck down. See if you can find that.
Old 03-17-2009, 10:30 AM
drob99 drob99 is offline
Believe it or not but I use walgreens super glue thats about $3 or $4. It holds really good. Try it !!!
2002 Pontiac Grand Prix GT 130K miles
