Old 03-07-2009, 06:21 AM
adz13091982's Avatar
adz13091982 adz13091982 is offline
Glueing clear parts
Which glue should i use on clear parts? plastic cement or ca glue?
Old 03-07-2009, 08:37 AM
drunken monkey's Avatar
Razor Sharp Twit
Re: Glueing clear parts
From the FAQ
it's amazing what kind of basic modelling information you can find there.
AF's Guidelines
Read them.
Old 03-07-2009, 04:28 PM
Twowheelsrule Twowheelsrule is offline
Originally Posted by drunken monkey View Post
From the FAQ
This site does have a wonderful FAQ section I recommend it.
The page that came up didn't really say what brand of glue to use so, here goes.
You can use my favorite Testors Clear Parts Cement, white glue, 5 min. Epoxy, or Microscale Micro Kristal Klear.
Hope that helps,
Mark
Old 03-07-2009, 04:30 PM
ketje's Avatar
ketje ketje is offline
I use wood glue or microscale crystal clear
Old 03-08-2009, 04:50 AM
Gone for the Microscale Krystal Clear - been using plastic cement with varying results
Old 03-10-2009, 12:08 AM
guiwee's Avatar
guiwee guiwee is offline
As for me ive used all of above except epoxy/
1.elmers..sometimes drys a bit yellow.not as strong.or clear
2.testors..mine has long curing time..dries yellow sometimes
3.microscal kristal clear...best for me.strong..dries clearest of 3(to me)
Old 03-10-2009, 02:22 AM
Tibi Keke's Avatar
Tibi Keke Tibi Keke is offline
Microscale Micro Kristal Clear is the glue you should go! Is drying clear, any excess you could remove with a wet q-tip. I'm glueing every clear parts (car windows and lights, plane canopy's) and also parts they are already painted because normal glue could damage the paint.
Tibi
Old 03-10-2009, 02:36 AM
wouter1981 wouter1981 is offline
Microscale Micro Kristal Clear is a very good product, I use it for 90% of the clear parts. It's relative strong, mistakes are easily corrected,... For bigger parts i use 2compound gleu, but you have to verry care full not to make a mistake.
What ever you do, don't use supergleu or plastic gleu.. it will destroy the parts.
Old 03-10-2009, 07:57 AM
Cold_Fire Cold_Fire is offline
Vendor
Microscale kristal clear is an easy option to find. You could also look for some non modeller specific vinilic glue. It will dry as hard as kristal clear or even harder, and it will be 100% clear.
There are really fantastic vinilic glues for book binding.
Old 03-10-2009, 01:02 PM
taliesen's Avatar
taliesen taliesen is offline
I recently started using "G-S Hypo Cement" that I got from MicroMark. Comes in a tube with a built in fine tip applicator. Dries crystal clear, seems to be plenty strong - but it is a little thick, and you have to watch out for 'stingers' when you pull the tube away from where you've applied it. Is sometimes easier to squeeze some out and apply with a toothpick.
Jonathan
Current projects:
1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745
Completed projects:
1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988
No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced.
Old 03-13-2009, 06:50 AM
Dingo1 Dingo1 is offline
I just use ordinary PVA glue or wood glue as it dries clear and does not make too bad a mess if you get it on painted parts also it cleans up with water while still damp and when dry you can lift it off after trimming with a sharp knife without any marks left behind I find it great stuff and cheaper than most scale model based clear glues.
Dingo
