Old 03-03-2009, 04:52 PM
bigbearzfan bigbearzfan is offline
91 C1500 Starts & dies intermittedly
I have a 91 1500 with a 5.7 TBI. Sometimes the truck will start then die right away or run for just a few seconds then die and wont start until it sits for a while, almost like its flooded, then it will be fine. There is no pattern it just does it at random. The fuel filter is new, the fuel pump is a year or two old, plugs wires cap are all good TPS is new the, all coolant sensors are new. Should I be looking at the fuel pressure regulator??
Old 03-04-2009, 08:35 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 91 C1500 Starts & dies intermittedly
I'd double check the fuel pump if it's not a Delphi/OEM and the wiring to it for good voltage and ground, then check the ignition coil, then fuel pressure regulator. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-04-2009, 09:12 AM
j cAT j cAT is offline
I believe the regulator may have a bad diaphram, as you suggested ,,,the age , and others with TBI have had this issue.
let the us know how it works out..
