weird ecu codes
ok this is really weird, I cant even deciefer this :
7short, 1 long pause w/4 short, 1 long, 1 long, 1 long, 1 long w/3short???? 7, 14??, ?????? |
What ecu are you running? Have you swapped in a new engine?
91 civic 4dr b16a 14.8@94 |
I looks like you're running and OBD1+ ECU.
7,14,43 OBD0 ECU's have on duration you just count the flashes. |
ok, here is the deal
91 integra ecu - pr4 obd-0 same codes w/ pm6 jdm sohc ZC - obd-0 dx harness w/ mpfi conversion obd-0 BUT : 92 jdm intake manifold (p08) or p28 SI but have 90 SI injectors on it only thing that is obd1 is : -tps sensor -eacv -intake temperature sensor -map sensor right on T/B I dont think that would cause biggies? |
IF its the same codes as a PM6, then it will not have any long/short beeps. non OBD (OBD0) ECUs just flash a steady number of beeps followed by a pause. count the number of blips in between the pause and you have your engine light.
And on those sensors, i am running a PM6 with the same OBD1 sensors as you have, it makes no difference, they will work OBD0. |
ok, Im gonna re-check with pm6,
tps is .5v closed butterfly, and 4.5 open?? and the two wires for eacv, are blue/black, and blue???....this im unsure maybe this is why my car runs fucking RICH!!!!, it stinks!!!!
also the IDLE lopes from 700-725-700-etc
I hate that shit, I have a honda, not a 5.0 with lumpy cam |
