Old 02-28-2009, 04:46 AM
gtziaf's Avatar
gtziaf gtziaf is offline
Alclad paint on Zero Primer?
Hello again.
Another quenstion...
Can I use Alclad II aluminum paint on Zero Grey Primer?
Also, Alclad paints and Alclad primer needs thinner for airbrushing.. If yes what kind?
Thanks for your time.
Old 02-28-2009, 05:34 AM
stevenoble's Avatar
Re: Alclad paint on Zero Primer?
Originally Posted by gtziaf View Post
Hello again.
Yes, you can use the aluminum Alclad on Zero grey primer. I usually use it over black though for a better finish. I use regular lacquer thinner for the Alclad paints. Never used their primer though so maybe someone else can answer that question for you.
Steve Noble
Old 02-28-2009, 10:05 AM
taliesen's Avatar
taliesen taliesen is offline
I've never had to use thinner for Alclad - it works just fine straight out of the bottle. I'm guessing older paint might need some thinner - but if you just bought it and you think it needs to be thinned, talk to your retailer about replacing it.
I do use the Alclad airbrush cleaner when I'm done, it works great.
Jonathan
Current projects:
1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745
Completed projects:
1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988
No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced.
Old 02-28-2009, 11:24 AM
gtziaf's Avatar
Thanks mates!
It 's works.
I clean my airbrush with zero paints cleaner with good results.
Thanks a lot...
