Old 02-13-2009, 04:23 AM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Question Brake problem on 1995 Lesabre Custom
1995 LeSabre Custom 140,000 miles
ABS Brakes - No Brake/ABS lights on
when you are going like 50 mph if you push the brakes to stop they go like half way to the floor and you dont really stop to well...
but if you let off and repress the brakes they go about 1/4 way down and work great.
Any ideas? The car isnt mine its my sisters and shes only home like once a month so wont really be able to check anything right away but advice is always nice.
Old 02-13-2009, 06:18 AM
polarzak polarzak is offline
Re: Brake problem on 1995 Lesabre Custom
Sounds like the brake booster is a problem. Big round thing on the fire wall.
Old 02-13-2009, 08:20 PM
Blue Bowtie's Avatar
Registered Offender
Check the rear brake adjustment. If that is correct, check the master cylinder.
Old 02-13-2009, 09:31 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
In addition, check the MC reservoir for proper level of fluid. If low, look for leak between the MC & booster, it will drain down to the bottom of the booster. Also, check rear wheel cylinders for leaks.
Old 02-13-2009, 11:58 PM
well i know its topped off on fluid and i dont think its a booster problem cause it doesnt seem like you have to push hard to get it to brake. But i will look at the adjustment of the rear brakes. i believe it needs new rear drums and shoes anyways cause the front brakes look pretty new but the back end feels like ovals when you brake hard
