Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-07-2009, 12:49 AM
GreyGoose006 GreyGoose006 is offline
spring rates
does anyone know the stock spring rates or MOOG p/n's for a typical hd suspension optioned caprice?
i am looking at getting a weight jack suspension and racing springs but have no idea where to start with rates.
thanks
Old 02-08-2009, 08:38 PM
moliva1568 moliva1568 is offline
Re: spring rates
Based on my bad experience today with this same exact issue, heavy duty moog springs for the front have the product #5428. The springs for the rear are #5419. These apply to 4 door sedan with A/C. I know this because i had the unfortunate experience of having some front springs placed in the rear. I posted a thread about this. any help onm that would be appreciated.
thanks
Old 02-11-2009, 03:18 PM
Re: spring rates
any other ideas out there?
c'mon, where are all the big guys that are always on here.
i know i havent been here in ages, but hey.
are you sure about those pn's?
the info i have from moog says that the front springs you listed have a rate of 393 lb/in
thats quite low considering the rears are 173 lb/in.
as a comparison, my camaro has moog 5662 fronts which are 707 lb/in rate
the rears are in the 150 lb/in range, but i cannot remember the pn's off the top of my head.
http://bbb-carb.com/moog_Coil_Springs.htm
this is the chart i am using.
and yes, the 5662 and 5664 is incorrect in the chart.
switch the rates for those two.
the 5664 has a heavier wire diameter.
Old 02-11-2009, 08:20 PM
CD Smalley CD Smalley is offline
Re: spring rates
K584s for the front. I used them on my 89 9c1.
Several others have used them when doing big-block swaps to even out the ride height.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-12-2009, 12:24 AM
Re: spring rates
you mean moog 584?
that looks way too long. the free height is 16 inches.
edit, nvm, the stockers are 16" long too
