Old 02-06-2009, 01:24 PM
anovib anovib is offline
starts then stalls
2002 Grand Prix GT. this is a one time incident so far.
1st try ___Starts then stalled
2nd try ___Starts then stalls
3rd try ___ cranks will not start
two hours later.. Starts as normal..
update two days later still running fine. Afraid what may be around the corner. Any ideas?
Old 02-06-2009, 10:42 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: starts then stalls
when it stalls do any lights come on? "Trac Off" by chance? This indicationg a failing crank position sensor.
You could also try unplugging the MAF sensor to see if it will start with it unplugged.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-07-2009, 07:39 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Tim, your symptoms are indicative of either a bad CKPS or MAF sensor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-07-2009, 09:31 AM
CrazyHorst CrazyHorst is offline
I've had this happen a couple of times recently...so far has gotten started each time. This seems to happen at a gas station fill-up (??).
Anyway, what I've been doing is to key up to the 2nd position to allow the fuel pump to run a little bit then it seems to hit on the 2nd try.
I do have plans to replace the crank sensor at my next planned maintenance session.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 02-07-2009, 04:34 PM
tblake's Avatar
In God We Trust
crazyhorst, your issue almost seems like a fuel delivery problem.
Old 02-07-2009, 05:06 PM
It may very well be...my bro had the fuel pump replaced under duress about 120k but not with a GM-Delco part....it is on the list...I was planning to wait about 2 years before I dug into it again unless forced sooner......
2009 G8 - GT (46k)
Old 02-07-2009, 05:55 PM
tblake's Avatar
In God We Trust
on the list.....
(seems to get longer and longer doesn't it?) Same for me, there are a bunch of things on my list. Just not enough time.
How has your car been since the most recent service?
Old 02-07-2009, 07:04 PM
The car has been running well as far as I can tell. The running average mileage on the DIC was topped out at 25.2mpg max before the service, I saw 26.6mpg on Friday. Not that this is the absolute source of truth on mpg, but at least an apples-to-apples comparison.
My one major driveability issue was the 4th gear TCC locked, ~45mph under 2-3 bars of boost, usually "lugging" uphill where it would stumble badly. This is completely gone.
In other interesting technical news I learned that the GTP has likely never seen a drop of premium fuel other than what GM put in it at the assembly plant. Conversations with my brother indicated he never put anything other than 87 octane pump-regular in it and neither have I. So maybe I'll be a cautionary tale. Maybe not...its mostly been a commuter car with a slight bit of rock-n-roll mixed in.
Regarding list of projects...you see I have 4 hi-milers...current limitation is to get a personal shop facility going in my new location. Hopefully planned for this summer.
2009 G8 - GT (46k)
Old 02-08-2009, 08:51 AM
rev2red's Avatar
rev2red rev2red is offline
Send a message via MSN to rev2red
CPS have something to do with it, is engine light on?
