| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Alclad for F1-wheels?
Iīm searching for the right colour of the typical silver and gold BBS wheels of Formula 1 cars. Unfortunately iīm not sure, if "ALC 101 Aluminium" or "ALC 105 polished Aluminium" resp. "ALC 108 Pale Gold" or "ALC 118 Gold Titanium" would be the better choice, as i havenīt used any of those paints so far.
Any experiences or even pictures of painted wheels? ![]() http://www.flickr.com ![]() http://www.ferraris-online.com
Julian |
Re: Alclad for F1-wheels?
The Alclad regular Pale Gold is a little too dark for the Ferrari wheels, but you can lighten it with a little Aluminium, I've done this before.
Steve Noble |
I haven't done this myself, but the White Aluminum might be a good choice for the newer rims - I think the polished aluminum would come out a bit too chrome like, and the regular aluminum might be a bit too dark.
I like the idea of pale gold mixed w/ aluminum - the titanium gold color I think is a bit too brown to serve as a base.
Jonathan Current projects: 1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745 Completed projects: 1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988 No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced. |
Pale Burnt Metal is perfect for the gold wheels. Gold Titanium is very light (almost silver), Pale Gold too gold.
I use White Aluminium for the silver but HPAluminium over a satin black is also good. |
I'm with stevenoble on this. Pale Gold mixed with Aluminium.
i use the cheap aluminum spray from canadain tire. then rub on pencil led to bring out some shine.
Thanks for your help! So i should go with Pale Gold/Aluminium for the golden wheels and White Aluminium for the silver wheels.
I primarily thought of Alclad because of no visible metal flakes, but your wheels donīt look bad at all, James. Did you give them a clear coat?
Julian |
Just for reference, the wheels on the right are White Aluminum, and I don't think it's shiney enough for what you need. Admittedly the shots were taken in quite low light, so perhaps it would work - I'm not 100% sure, but I tend to doubt it has quite enough shine. If you could tone down the Alclad Chrome that might work, but I'm not sure how you'd do that - perhaps spray it on a higher pressure setting, or over unsanded primer.
![]() And the image below shows Alclad Pale Burnt Metal between the yellow on the fuselage and the gunmetal colour on the jetpipes. It was sprayed straight over the yellow. ![]() ![]() I'm not normally one for aircraft, but occasionally one of these little 144th scale kits interests me. Hope that helps a little! |
Thank you very much for those pictures!
I agree, white Aluminium does not seem to be shiny enough. I have to order polished Aluminium anyway so i will try that first. Never thought that "Burnt Metal" would look that golden. Took a look at some ref. pics at the alclad page and it appears much darker there.
Julian |
Hi, maybe its just me, but i feel that polished aluminum is a little too shiny, and i think alclad white aluminum is closer to the real wheels. Or i can suggest silver leaf TS-30 too with a little pencil led or smoke for weathering.
Ro
![]() ![]() ![]() ![]() ![]() ![]() ![]() http://absolutmodeling.blogspot.com Current project Ferrari 248 F1 Ferrari 250 GT California Spyder |
You might try Mr Aluminium. Quite bright and shiney, dries very fast and is much more wear resistant than Alclad.
The rest of the Mr Metallics line is also good. I get mine from: http://www.shopcreator.com/mall/depa.../1/1/%2D/60603 The colour and shine from some of the Alclad paints does change quite a bit depending on the base coat - matt, semi matt, gloss, enamel gloss, black / other etc. and also how heavy it's sprayed on - heavy coats lose shine. White Aluminium can change quite a bit depending on the base coat and HP Aluminium will lose some of its polish if it's sprayed over a matte base. |
