Old 01-30-2009, 06:12 PM
nicnicbubba nicnicbubba is offline
Brake lights on f-350
My 2004 F-350 diesel does not have any brake lights. Fuses and bulbs are good. Any suggestions?
Old 01-30-2009, 10:43 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Re: Brake lights on f-350
Does the high mount center light work? The side lights run through the multifunction switch, which I've replaced many of, the turn signals might still work, as well as the running lights, but if the middle light works, then it is almost a guaranteed multifunction switch.
Old 02-03-2009, 11:51 AM
FNA FNA is offline
Check the switch?
"almost a guaranteed multifunction switch."
What do you mean? I've been out of the business for a while, but I didn't know there were multifunction switches in the brake light system. Wouldn't there be a 'stand-alone' brake light switch and a stand-alone hazard flasher?
Old 02-03-2009, 05:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Brake lights run through the turn signal( multi-function) switches if it has a dual filament bulb. It could also be the brake light switch since there are 2 circuits coming out of the switch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-04-2009, 10:16 AM
FNA FNA is offline
Thanx.
You have had to replace a lot of TS switch assemblies for failed brake lights?
As I said, I'm out of the business now, but in over 10 years, I don't think I ever did.
