Old 01-28-2009, 09:38 PM
IMarriedaCamaro IMarriedaCamaro is offline
replacing 305 heads. any tricks will im here?
I have a 87 Camaro with a 305. I have a Edelbrook 4 bbl 850cfm with a stock intake......No comment on the intake .... i have recently replaced forged crank,bearings,forged rods.pistons,rings, all gaskets, perfomance clutch and pressure plate, borg warner 5 speed man, and many other littel things. about 6 monthes after the rebuild i smoked both heads......I was wondering if there is any tricks i should do while im here to add any more power. It runs mid 11s now and id like it to hit early 10s. Is there any heads without spending buko bucks i could put on it to up my game? ANY SUGGESTIONS WILL BE APPRECEATID!!!
Old 01-29-2009, 01:20 AM
Morley Morley is offline
Re: replacing 305 heads. any tricks will im here?
305 heads are VERY limited. The best head for the 305 were the original Trick Flow twisted wedge heads for the 350. They don't make them any more (they had problems).
One thing that comes to mind would be porting them and then installing 1.94" intake valves and 1.5" exhaust.
Old 01-29-2009, 01:41 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
I find that hard to believe with a 305, stock heads or aftermarket. Unless you're spraying the piss out of it, or boosting the piss out of it.
Old 01-29-2009, 02:04 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
exactly what i was thinking. mid 11's on a 305 if a major feat
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
