Old 01-27-2009, 09:39 AM
copperyj copperyj is offline
front end noise, 2001 GP
Alright, long time reader, 1st time poster. But I had a real loud grinding/whining/friction sound coming from the front end of my 01 GP. What I thought was a bad hub bearing. Car has 115,000 miles, so I went to O'reilly and both two (one for each side). I don't remember the name brand, but they were the "middle of the road" on price. Not the most expensive, but not the cheapest one's either. $130 a piece I believe. But i put them on, and the noise is still there. What else could it be? Could it be the drive shafts? If so, what's all involved with replacing those? Thanks
CK
Old 01-27-2009, 10:13 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: front end noise, 2001 GP
what sort of noise is it? rubbing, or grinding? does it happen while accelerating?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-27-2009, 10:19 AM
Sounds like a grinding noise. It is speed drivin. The faster I go, the louder it gets. Throw the car in neutral, the sounds stays the same. Sounds like I have a pair of Off-road tires on the front. Like a loud humming sound. If that makes sense.
Old 01-27-2009, 11:10 AM
tblake's Avatar
In God We Trust
I had sort of an issue like that. Turned out to be the tire rubbing on the splash gards. The plastic clips had fallen off and left the gard to rub on the wheel. Mine was the one on the passenger side by the oil filter. Once I added some new clips, its been fine.
If these look good, you may want to have a look at your CV shaft boots. Maybe one cracked and flung grease all over the place. It would be an indicator that the grinding noise could be a bad CV axel.
What brand were your wheel hubs? BCA national maybe? Did your torque the axel nut to the correct spec?
Old 01-27-2009, 11:29 AM
I don't remember what brand it was. The nut was extremely hard to remove, I had to use a breaker bar. So I put it on the same way. I didn't torque it to any specs, I just tightened it as tight as I could get it.
Old 01-27-2009, 08:26 PM
CrazyHorst CrazyHorst is offline
Along with other suggestions, it might be a good idea to check brake rotor temps to make sure they are roughly equal after a drive....
Also I'd rotate tires fronts to backs. I have heard of a tire delaminating around the circumference which didn't cause a blowout but caused strange noises.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
