Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-27-2009, 05:21 AM
bigal6030 bigal6030 is offline
New Distributor cap/rotor now it won't run
I installed a new distributor cap and rotor and now my 96' 4 cylinder Camry won't run. It starts but dies when I let up on the gas.What the heck did I do wrong? I was careful with the wires and double checked everything. I did not change the wires or plugs. The old cap and rotor were worn but the car ran ok. Can someone help me out. Yes I used OEM parts.
Al
Old 01-27-2009, 10:23 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: New Distributor cap/rotor now it won't run
You probably knocked a connector or vacuum hose loose near the distributor. Disconnect and solidly reconnect everything anywhere near the distributor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-27-2009, 11:22 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
What was the reason you replaced them in the first place? The most typical reason nowadays for a non-start on these Gen III Camrys is the ignition coil. They will act like that when they're in their final gasp...engine will only start with throttle applied and then die when you let off. And sometimes they just DIE. You've got a gasping one, I think. Check the resistances of the coil's primary and secondary terminals...if they're close to or out of spec, replace it. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-27-2009, 11:40 AM
FRANKENCAMRY FRANKENCAMRY is offline
Make sure the firing order is correct.
(I have a Haynes manual that shows an incorrect order)
Old 01-27-2009, 12:39 PM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Al
Check the resistance on the spark plug wires.
They're kind of delicate and could have been damaged when removed.
That could be your problem.
Perhaps I'm going over board, but I change the plugs, wires, cap, rotor, and gaset under the cap, plus distributor O ring, together.
First time I checked spark plug wire resistance I got two at infinite resistance, they had been shorting down inside the spark plug tubes.
The manual has the specifics, something like not more than 15K ohms.
